Book matched or slip matched?
Forum topic by jsvenson11 posted 09-27-2019 11:19 PM 557 views 0 times favorited 15 replies Add to Favorites Watch
View jsvenson11's profile
jsvenson11
16 posts in 1113 days
09-27-2019 11:19 PM
I ordered 15 sheets of slip matched cherry veneer for cabinet fronts. I did slip matched to avoid the “barber poll” effect that happens with book matched cherry because of the loose-tight grain alternation from the veneering process. The pictures are what showed up today (not great lighting). The first picture shows the “barber pole” stripes at the far end. Next to show flitch pattern. I’d like to be reasonable with the lumber yard, but I’m pretty sure that this is book matched. To make sure I’m not nuts, I’d appreciate any other second opinions. Thanks in advance.
15 replies so far
View Rich's profile
Rich
6507 posts in 1594 days
#1 posted 09-27-2019 11:37 PM
Looks slip matched to me.
jsvenson11
#2 posted 09-27-2019 11:45 PM
- Rich
Thanks, Rich. The mirrored aspect of the grain in the second two pictures and the barber pole effect in first picture make me think its book matched but I don’t have a lot of experience comparing book vs. slip. Is there anything you’re looking at that tells you its slip matched?
Other flitches seem to be fully slip matched like this one:
View LeeRoyMan's profile
LeeRoyMan
1531 posts in 732 days
#3 posted 09-28-2019 12:13 AM
What you needed was a rotary cut 1 piece face.
jsvenson11
#4 posted 09-28-2019 12:20 AM
- LeeRoyMan
Considered that but it gives a much different grain pattern than we’re going for. Slip matching avoids the barber poll and gives a straight grain across the sheet. Rotary gives a wide open, varied grain. For example
View Rich's profile
Rich
#5 posted 09-28-2019 12:21 AM
Looking more closely at the second photo in your original post, I have to correct myself. I did not originally see that joint down the middle of the rows. So yeah, it’s looking more like a series of book matched pieces. It’s difficult to say with 100% certainty from the photos though.
View Aj2's profile
Aj2
3662 posts in 2803 days
#6 posted 09-28-2019 01:58 AM
That’s booked matched for sure on one side. But what’s on the other side
-- Aj
View TungOil's profile
TungOil
1383 posts in 1500 days
#7 posted 09-28-2019 02:30 AM
It’s book matched. Look at the table top in my projects page to see an example of a slip match.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Tony_S's profile (online now)
Tony_S
1422 posts in 4088 days
#8 posted 09-28-2019 10:38 AM
- jsvenson11
That one is book matched as well, just like the rest.
- LeeRoyMan
For shame LeeRoy….The elitist snots will be looking for blood.
btw…I’m still holding that job opening for you ;)
-- “Wise men speak because they have something to say; fools because they have to say something.” – Plato
LeeRoyMan
#9 posted 09-28-2019 01:35 PM
btw…I m still holding that job opening for you ;)
- Tony_S
LOL, Right on brother, Mom still has a few more years to go.
Then you might see someone that resembles LeeRoy knocking at your door…. :)
View splintergroup's profile
splintergroup
4635 posts in 2227 days
#10 posted 09-28-2019 02:06 PM
I’d call it slip matched. I don’t see the mirror pattern of book matched since all bends in the grain go the same direction, If you could indicate more clearly in the photos where the seams are, it’d be a lot easier.
View Rich's profile
Rich
#11 posted 09-28-2019 02:11 PM
I d call it slip matched. I don t see the mirror pattern of book matched since all bends in the grain go the same direction, If you could indicate more clearly in the photos where the seams are, it d be a lot easier.
- splintergroup
I thought the same thing initially. If you look closely at his second photo (I had to zoom in) in the main post, what at first appeared to be slip matched strips actually are book matched. There is a joint that’s barely visible down the middle of each of those strips.
The site compresses photos so much that any details are lost.
TungOil
#12 posted 09-28-2019 04:58 PM
- splintergroup
I thought the same thing initially. If you look closely at his second photo (I had to zoom in) in the main post, what at first appeared to be slip matched strips actually are book matched. There is a joint that s barely visible down the middle of each of those strips.
- Rich
It fooled me at first glance as well, but it’s definitely book matched. I don’t recall ever seeing commercial slip matched veneer, now that I think about it. Not saying it’s not available, but I have never come across it, only book match and rotary sliced.
Tony_S
#13 posted 09-29-2019 11:03 AM
- TungOil
With all the commercial suppliers I’ve ever dealt with, a slip match would typically be a custom press.
Just thinking out loud here….
From my experience, it’s unusual to see a rift/quartered ‘book match’. Which is what the OP has. Book match sheet goods are almost always flat sawn (Cathedral grain). Rift/quartered veneer flitches would ‘typically’ be narrower, just like solid lumber, so using it for a book match is only going to increase, or magnify the barber pole effect because there would be more pieces/48” width (as above).
splintergroup
#14 posted 09-29-2019 01:52 PM
- Rich
Good eye! Even close up it took me a while to find the line. That photo is booked.
splintergroup
#15 posted 09-29-2019 01:56 PM
- TungOil
I was a bit biased since I bought a stack of office doors at auction a number of years back. Really nice rift sawn red oak, definitely slip matched. I’d assume for production goods it may all depend on what the assembler was thinking that day.
