Forum topic by Marleywoodie | posted 09-24-2019 02:14 PM | 1989 views | 0 times favorited | 35 replies | ![]() |
Hi Friends, The DC system in my shop has developed a distinct last of suction. All the hoses are clear and the gates are properly closed. Used to be much more suction. A while back the motor was making a funny noise when shutting off/winding down, but it sounds OK(ish) now. I took the squirrel wheel cover off, and all the blades on the impeller are find. Is it time to put her down? It’s a Central Machinery 2HP. It’s gotta 10+ years old, I’m not the original owner. -- - Not all who wander are lost - |
35 replies so far
#1 posted 09-24-2019 02:16 PM |
Plug |
#2 posted 09-24-2019 02:57 PM |
Still sporting the cloth bag for filtration/air movement? If so they are the weak spot, and if you swapped to a pleated type filter, or even shook the daylights out of that bag, and then sent it through a trip through a LAUNDROMAT washer dryer. Believe me Momma would kill you using the home equipment….. I think the cleaning, or all together swapping out of the filter material would also bring around the suction you remember. Maybe even better with a pleated filter. Probably the most often suggested pleated filter comes from here. Cleaning the filter costs almost nothing, and would quickly tell you if you were on the right track. If right after you are seeing renewed suction, you know which way to head. If the $$$$$ for the filter is more than you want to put into the HF system (understandable) then you know on a semi regular basis you need to make a trip to the laundromat. Seeing as it’s still comfortable weather everywhere in the US, if you had a washtub, you could shake it out, suction it off with a shop vac from the inside, where all the junk hits it, then dunk it several times in some soapy water, then hang it outside to dry. What happens is the pores of the cloth get filled with dust, sap, and whatever from the wood, and just plug the cloth fibers so they will hardly allow water to pass through. You need to wash that stuff out completely, then after it dries, “almost” as good as new. There will come a time, when even washing doesn’t help anymore, and buying a new cloth bag, or a pleated filter are your only option. -- Think safe, be safe |
#3 posted 09-24-2019 05:09 PM |
Check all of your lines to make sure there aren’t any pieces of wood scrap or shavings hung up in it. Clean out your filter. Make sure the shaft bolt holding the impeller on the motor shaft hasn’t worked loose. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#4 posted 09-24-2019 06:19 PM |
+1 what they said above.
First: Did you spin the impeller by hand, and check the motor bearings for noise or play? If motor is ok, and don’t have loose wire: next most likely reason for lack of suck is filter medium is clogged. If a bag, take it off, turn it inside out, and beat the dust of it outside wearing mask. If pleated filter, gently use air hose and blow the dust out of pleats from outside. Both of these are considered regular maintenance items. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#5 posted 09-24-2019 07:10 PM |
+2 to what has been said.as the cap’n said could be a bearing problem. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#6 posted 09-24-2019 11:54 PM |
Don’t wash the bag. The dust cake on the inside increases filtration. To a point. Shake and beat ( outside ) but don’t wash. |
#7 posted 09-25-2019 06:39 AM |
I own a HF dust collector, and unlike many of the higher end DC’s the bags on them aren’t treated with anything more than the size of the holes in the material. 5 Micron, bats can fly through the pores, no treatment. For the OP, try just using a shop vac, and compressed air to clean it. see if anything happens. If all else fails, and you are going to have to buy another bag, or a pleated filter, what do you have to lose, wash it. I have mine several times, and it improves the air flow, and thus the suction. -- Think safe, be safe |
#8 posted 09-28-2019 04:03 PM |
If you get nothing else out of this thread listen carefully to the advice quoted above…... I lived, but it was a touch-n-go situation. -- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.--------- |
#9 posted 10-17-2019 02:18 PM |
So, update, after cleaning out the upper bag, it appears suction is much better. I can’t check the full system as my shop is torn up due to replacing the windows in it. I’m going to re-run the hose for more clear routes with less dips, etc. I’ll update when I get that completed. Thanks for all the suggestions. -- - Not all who wander are lost - |
#10 posted 10-17-2019 03:52 PM |
For better suction, put in hard duct.. A world of difference over hose…even straight hose has a lot of drag. |
#11 posted 10-17-2019 06:04 PM |
What do you use for that? -- - Not all who wander are lost - |
#12 posted 10-17-2019 06:16 PM |
I use steel duct, 26 guage, 5” diameter. The ridges in the hose really slow things down. |
#13 posted 10-17-2019 10:56 PM |
I use 4” PVC the thin stuff, not schedule 40 and it works great, much better than the hose. -- John D, OP, KS |
#14 posted 10-17-2019 11:55 PM |
Ridged hose is the lowest denominator to carry stuff to the vac. Smoother the better, and on sweeps, and turns the gentler the arc the better. hard 90’s on ridged plastic hose can stop you dead in your tracks if you are using it on runs. Now a 10’ piece of ridged plastic hose on a DC you are bringing around tool to tool will work ok. So it really matters the type system you are talking about. -- Think safe, be safe |
#15 posted 11-14-2019 10:07 PM |
Where do you get that? I quickly realized regular 4” PVC was overkill… -- - Not all who wander are lost - |
Forum | Topics |
Woodworking Skill Share
13143 |
Woodturning
2784 |
Woodcarving
565 |
Scrollsawing
413 |
Joinery
1871 |
Finishing
6303 |
7860 |
32549 |
CNC Woodworking
325 |
Hand Tools
6424 |
Jigs & Fixtures
1787 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2617 |
1267 |
Woodworking Trade & Swap
5396 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
