Plugged end of the caulking tube
« back to Coffee Lounge forum
Forum topic by Jim Jakosh posted 09-23-2019 01:36 PM 904 views 0 times favorited 26 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
27012 posts in 4394 days
09-23-2019 01:36 PM
Topic tags/keywords: humor
I had to put new screws in a piece of trim the bay window and needed just little bit of clear caulk. I went to my stash and found I had opened 2 tubes so I picked one and thought I’d clean out the snout like I usually do with a drill and then get to the good stuff.
I cleaned out the snout and got a surprise. i still did not get to and liquid caulk. So I cut off the top to see what was there and it was a total solid. The same thing happened on the second tube so I did an operation on it and it was solid almost all the way. I did manage to get a tiny bit of liquid from the center of that long mass. I guess air gets in even though the snout has solidified .
This is your entertainment for the day…............Cheers, Jim
26 replies so far
View lew's profile
lew
13442 posts in 5044 days
#1 posted 09-23-2019 01:43 PM
I wonder if those “as seen on TV” tupperware type containers for caulking tubes work?
I don’t think I’ve ever gotten to use an entire tube of caulk before this happens to me.
View waho6o9's profile (online now)
waho6o9
9105 posts in 3865 days
#2 posted 09-23-2019 01:46 PM
After opening a tube up I wrap the end with electrical tape.
Sometimes I use a finish nail and electrical tape. YMMV
View pottz's profile
pottz
21383 posts in 2273 days
#3 posted 09-23-2019 02:15 PM
ive always used little red caps there like little condoms for caulking tubes,they work pretty well but in time the caulk still gets hard
View GR8HUNTER's profile
GR8HUNTER
9147 posts in 2001 days
#4 posted 09-23-2019 02:34 PM
- pottz
this is a family site LOL :<)))))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
View LeeRoyMan's profile
LeeRoyMan
2265 posts in 1016 days
#5 posted 09-23-2019 02:50 PM
Electrical wire nuts work the best. Been doing it for years. The threads grip the spout and keep it air tight.
View AlaskaGuy's profile (online now)
AlaskaGuy
6779 posts in 3598 days
#6 posted 09-23-2019 03:47 PM
https://youtu.be/0gJBkRl0HIg
View OleGrump's profile
OleGrump
581 posts in 1633 days
#7 posted 09-23-2019 03:58 PM
Two ideas which I have seen folks use to keep caulk/similar items for later use: 1. Wire nuts firmly attached to the end 2. Ubiquitous duct tape, long enough to be folded over and form a “tab” at the end to hang the whole tube vertically. I would lean more toward the wire nuts myself, for ease of operation.
-- OleGrump
View Jim Sellers's profile
Jim Sellers
519 posts in 3623 days
#8 posted 09-23-2019 04:25 PM
Even an unopened tube of silicone caulk will go bad after it gets old. If it comes out thick and lumpy it is bad and starting to gel. Not long ago I took an un opened tube to jobsite to caulk around a shower door frame. Looked fine coming out of tube. But it wouldn’t dry and stayed wet and sticky after many days. Checked date on tube and it was 5 yrs old
-- J.C.Sellers, Norcross, Ga. Just cut it right the first time. The best carpenters make the fewest chips.
View ddockstader's profile
ddockstader
225 posts in 4550 days
#9 posted 09-23-2019 04:38 PM
Sounds strange, but I use my wife’s Glad Press ‘N Seal. I cut off a 1” strip of that stuff and wrap it around the tip, fold in over and wrap some more. The stuff sticks like glue and is impervious to air. Six months later and my caulk is as fresh as the day I opened it.
View Knockonit's profile
Knockonit
1019 posts in 1491 days
#10 posted 09-23-2019 04:49 PM
lol, here in the desert you can count on it drying out based on your need of a small amount, even new tubes unopened dry out in a year or less if left in a tool box on truck the heat does it in for sure.
-- Living the dream
View corelz125's profile
corelz125
3895 posts in 2265 days
#11 posted 09-23-2019 06:44 PM
Half the time when I go to use a tube it’s expired.
View Joe Lyddon's profile
Joe Lyddon
10963 posts in 5341 days
#12 posted 09-24-2019 04:12 AM
Thank you…
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php?media/albums/users/joe-lyddon.1389/
View Zvonko's profile
Zvonko
142 posts in 1103 days
#13 posted 09-24-2019 12:00 PM
Half the time when I go to use a tube it s expired.
- corelz125
Guess I better start paying attention to the “use by date”. :)
-- You can't always control WHAT happens, but you can always control HOW you respond.
OleGrump
#14 posted 09-24-2019 01:42 PM
Being well past mine, I try to avoid looking at them…….. 8^)
-- OleGrump
Jim Jakosh
#15 posted 09-24-2019 04:15 PM
Well if you’ll notice, the date was 2015 on one of my tubes. No wonder. That tube had 4 birthdays before I tried to use it again. I know I have used the white calk when it was that old, though.
Cheers, Jim
