Forum topic by Willnsisu | posted 09-22-2019 06:31 PM | 591 views | 0 times favorited | 10 replies | ![]() |
Topic tags/keywords: panel saw circular saw blade full kerf question Hello: |
10 replies so far
#1 posted 09-22-2019 06:36 PM |
No, a 7.25” circular saw can not handle an 8” blade. |
#2 posted 09-22-2019 07:25 PM |
A cursory search online suggests that most “industrial” or full-kerf blades are 8 in. Read those descriptions completely. I think you may be seeing the outer rim blades for an 8” dado set. They will almost all be FTG grinds, and vary between 1/8” plates, and even up to 1/4”. This is a Dado blade, and is available in both widths. It was the first URL that came up on Goofle when I searched 7 1/4” circular saw blade, full kerf. So Goofle needs to pay attention to NUMBERS better than it does, but it is flawed. The problem you are seeing is the world is having thin kerf blades shoved down our throats. Cheaper to make, and they sell on the hype of geeee, you don’t lose all that material in the saw kerf, which is pretty much unmeasurable BS, so for them they use less metal, cheaper to make, and generally they cost more to buy, because they are soooo special. I've used these in circular saws for years when I didn’t want to keep swapping blades between crosscut 60 tooth, and rip cut 24 tooth. NO they are not carbide, but they cut for almost as long as i would use a carbide blade before deeming it went to the resharpen pile. I buy 5 or 10 at a time. Now that I am no longer doing trade work, I find they last long enough that they are still a good deal for me. Taking the model number, and just searching it, may find you better deals on them. I think if you search you will still find full kerf carbide blades as well, but make no mistake thin is in. So that sux if you have a safety device, splitter, that won’t work with the thin cut. A reasonable person would think this “Panel Pro” outfit would offer saw blades if they are selling something hard to find, but they don’t. -- Think safe, be safe |
#3 posted 09-23-2019 12:20 AM |
Thanks for your well-considered reply. Yes, a visit to Home Depot or wherever- will prove how- somehow- thin kerf blades have become damn near the only things you can buy. In fact, I could find no blades -of any size- that were not the of the ‘gee whiz thin kerf technology.” At least in the ten inch table saw world, thank goodness for the internet and the availablity for full-width goodies like the Forrest woodworker II, etc. |
#4 posted 09-23-2019 07:53 AM |
Not sure what actual measurement is for full kerf on 7-1/4 blade? Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#5 posted 09-23-2019 12:13 PM |
I don’t understand why a splitter is necessary on a panel saw. One would think that the rigidity of the frame plus the stability of plywood would obviate the need. What am I missing? -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#6 posted 09-23-2019 04:32 PM |
When you get right to the end of a horizontal cut, the top piece will pinch down on the blade. |
#7 posted 09-23-2019 06:51 PM |
Ahh so. Thanks, theart. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#8 posted 09-23-2019 10:36 PM |
Maybe you could swap out the splitter or riving knife for a thinner one. Shouldn’t be hard to make your own, if necessary. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#9 posted 09-24-2019 11:01 PM |
Using the numbers still visible on the old blade, I found an equivalent NOS saw blade on ebay. Thanks all for your input! |
#10 posted 09-25-2019 06:43 AM |
Glad you got hooked up. -- Think safe, be safe |
Forum | Topics |
Woodworking Skill Share
13205 |
Woodturning
2815 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1900 |
Finishing
6352 |
7914 |
32786 |
CNC Woodworking
330 |
Hand Tools
6456 |
Jigs & Fixtures
1809 |
Wood & Lumber
7284 |
1634 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9664 |
