Nail Hole Filler
Forum topic by Redoak49 posted 09-22-2019 02:51 PM 775 views 0 times favorited 15 replies Add to Favorites Watch
View Redoak49's profile
Redoak49
5417 posts in 3270 days
09-22-2019 02:51 PM
I am building some book shelves with Red Oak and using 18 ga brads in places. I want to fill the holes before finishing. I will be staining with oil based stain and will use oil based poly.
What can I use that will take the stain and not be very visible?
15 replies so far
Rick Dennington
7176 posts in 4476 days
#1 posted 09-22-2019 03:09 PM
Go to Lowes or Home Depot and pick up a bottle or tube of oak wood filler….Push a small amount of filler into the nail hole, let it set until it starts looking dry. Wipe off excess with a damp rag (don’t wipe all of the filler out). Once dry, sand lightly till the filler looks like it disappears….The hole is filled, so stain or paint your project….!!
-- " There's a better way.....find it"...... Thomas Edison.
View bilyo's profile
bilyo
1421 posts in 2384 days
#2 posted 09-22-2019 03:24 PM
+1. I would only add the suggestion that you do some tests on scrap. Sometimes your stain will color the filler differently. You may want to adjust the color of the filler.
An alternative is to put some sanding dust into the nail hole and then put a drop of super glue (not gel) on top. Let it set a few seconds and then sand it smooth.
View Kazooman's profile
Kazooman
1540 posts in 3234 days
#3 posted 09-22-2019 03:35 PM
I would use Timbermate if I had to use anything.
Why use the brads in the first place?
Redoak49
#4 posted 09-22-2019 09:43 PM
I am using the brads to speed assembly of attaching strips to the front and back of the shelves.
I used the Sagulator to calculate the size of the strips to minimize sag.
Kazooman
#5 posted 09-22-2019 09:54 PM
- Redoak49
That is a great way to keep the shelves from sagging and the visual effect of the wider piece is a good design decision. A good combination is a plywood shelf with solid wood for the facing strips. If you cut rabbets in the strips you do not need a whole lot to keep them attached to the shelf pieces during glue up. A few pin nails or even strips of blue painter’s tape would suffice and would probably not require any filler. My concern is that you will have a line of filled brad holes that will be readily apparent.
View Axis39's profile
Axis39
565 posts in 879 days
#6 posted 09-22-2019 10:35 PM
What color stain?
Might think about a color matched china marker to keep around for after finishing…
As for filling, I am a fan of Timbermate. You can get colored versions. You can also try the white and stain on a test piece.
-- John F. SoCal transplant, chewer uppper of good wood
View GR8HUNTER's profile
GR8HUNTER
9126 posts in 1994 days
#7 posted 09-22-2019 11:18 PM
i always had very good luck with Famowood just my 1 cent YMMV :<)))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
View JayT's profile
JayT
6438 posts in 3493 days
#8 posted 09-22-2019 11:24 PM
- bilyo
This is what I do to fill small holes or gaps, though generally let it set more than a few seconds. It works well.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View Toller's profile
Toller
64 posts in 2882 days
#9 posted 09-22-2019 11:53 PM
Since you will never get a perfect match, go darker. It is much less visible then if it comes out lighter.
‘Timbermate is good stuff.
Redoak49
#10 posted 09-23-2019 12:22 AM
If you cut rabbets in the strips you do not need a whole lot to keep them attached to the shelf pieces during glue up. A few pin nails or even strips of blue painter s tape would suffice and would probably not require any filler. My concern is that you will have a line of filled brad holes that will be readily apparent.
- Kazooman
I am gluing up long pieces of hardwood ply with edging strips front and back. No matter What you do, the plywood always has a bit of a curve. I have red oak strips for font and back. Even though they were perfectly straight when I cut them they also have various curves. Blue tape will not be enough…I have I have tried that. I am using a spline and need the brads. I could put a zillion clamps but decided on the brads. I have made a lot of book cases and the brads will be fine and not visible in this application.
View mel52's profile
mel52
2277 posts in 1547 days
#11 posted 09-23-2019 02:45 AM
I’m with a few of the others on using Timbermate. Has always worked for me, ( so far ). Mel
-- MEL, Kansas
View SMP's profile
SMP
4947 posts in 1187 days
#12 posted 09-23-2019 03:44 AM
I like famowood and timbermate. But the only problem i have w famowood is the 2nd or 3d time i go to use it the can has hardened. The timbermate you can just add more water if needed.
Redoak49
#13 posted 09-23-2019 01:05 PM
Thank you all. I am ordering some Timbermate and will do some trials with it.
GR8HUNTER
#14 posted 09-23-2019 01:47 PM
famowood makes a GR8 solvent to soften up old cans you can also use acetone, Methyl Ethyl Ketone, naphtha :<))
View Bill_Steele's profile
Bill_Steele
779 posts in 3014 days
#15 posted 09-23-2019 03:10 PM
I think it is likely that no matter what you use to fill the 18g nail holes, you will still see some evidence of them after staining. Some people have good luck using glue and sawdust (from the same wood species). I like Timbermate and would suggest you try that filler. Maybe get a few different colors and mix them to get the right color. If possible I would suggest using a pin nailer (23g) because it leaves a much smaller hole.
