Today I pulled the trigger and bought a bunch of Sapele for a table top project I've been dreaming about for a long time. I asked the salesperson at the woodworking shop for finishing options that meet the following criteria: 1) Ease of application - I am very much a rookie with no finishing experience. 2) natural look - I don't want to stain the wood I just want to bring out it's natural beauty 3) I do not want a high gloss finish. I want something more subdued. 4) protecting the table from water and other liquids is a high priority. I can imagine one of my children spilling a glass of lemonade on the table and I want to protect the wood
The two products recommended where Watco Danish Oil and Oil Based Arm-R-Seal Satin finish. I was told that Danish Oil is a more widely used option but Arm-R-Seal will accomplish a similar level of water protection with fewer coats.
I'm curious what other people think about these two options. Also is there a third option that I am not aware of that can meet the goals that I stated above?
Personally i like the ptotection of ArS, seems to hold up better with kids and dogs etc. I use it quite a bit, but it does add the plastic feel of poly. I use the danish oil when i want to add a bit of tone to something, but that is rare. I tried the maloof formula and actually prefer that over regular danish oil, but again has a plasticy feel. Based on your 1-4 i would say the satin ARS, however, make sure to read all the instructions, especially in regards to stirring very well and stirring regularly, and temp and hunidity. Failing that can leave it looking streaky, etc, otherwise foolproof i even use paper towels to apply.
Danish oil is commonly described as a mix of BLO, varnish, and thinner….if you do your own is generally 1/3 each. Watco Danish oil is defined by Flexner as just being wiping varnish (a very thin varnish). That is also what ARS is as well, a thin varnish. The Watco uses a different resin (at least they used to) in that it's an alkyd varnish where the ARS is a urethane. We used to be able to tell how much thinner was in these from the MSDS, but that's not available anymore. Back to your question, Either will be very easy to use, and with enough coats either will do a good job of protecting the top. I'm not sure whther the ARS will take fewer coats, but I'd guess it would. The Watco used to be about 80% thinner (IIRC). You could buy a good quality varnish and thin it 50/50 to make your own wiping varnish, that would almost certainly build faster. Remember, these are oil finishes and will shift the color somewhat, to a more warm look. You can mimic what that will be by wiping some MS on the wood, that's also a good way to find unseen flaws you want to address before finishing. The MS will evaporate leaving the wood ready to finish.
I mix the two together at a ratio of 1:1 for a wipe on finish. Usually, 4 coats, decreasing the ratio of watco to poly with each coat. The 5th coat is straight poly. Have never had any complaints about it's water resistance or durability.
I agree that all of the above will work just fine. I think I would make at least two sample boards from scrap. Sand and prepare them equally. Then apply a coat of Watco on one. Let it dry and then apply 2-3 coats of Arm r seal. On the next board, just apply 2-3 coats of Arm r seal. Sand lightly with 220 grit between coats. Then, you might do a third one using Gene Howe's method. See which one you like the best.
As stated above, I would not use Watco alone. It will not protect as well. However, it is great for bringing out the color and grain of the wood.
As suggested there is NO substitute for prepping the same material as your project, sanded exactly the same, and do test applications before just diving in..
A masterful reposting of information freely available online to whomever bothers to look. However, without a response from the OP regarding the intended use of the table, any recommendations are moot.
Demonstrates that not all "woodworking shop" personnel know much about finishing. Those are 2 very different products that perform very differently. ARS, or other solvent poly products, dry to a hard protective finish with hi chemical and wear resistance. DO is much softer with much less chemical resistance - good for stuff to look at but not something that will see much use. Use a solvent poly. It will provide the same chatoyance or grain pop as the DO as well. As a newb, this will help you out. Applying 1st 2 coats - thin the ars ~ 4 to 1 part ms, flood it on for ~10 min and keep the surface wet allowing the wood to soak it in, then wipe off. Wait at least 2 hrs and repeat. Now the grain is sealed and you can wipe, brush, spray apply at the film thickness you want.
I don't know about the oil but Armrseal is great stuff. I've put it on dining tables and it's tough, tough, stuff. And I've both brushed and wiped it on with light sanding between coats not being as careful as I should and it just looks smooth and level every time.
The scenario of how I began using it long ago was I had this table and wanted the finish to be tough and look good. I didn't know what to do. One bad choice and it's ruined. This stuff made me look good without trying.
In response to question about what the table will be used for. It will be our family kitchen table and will get a lot of use both for meals and it will be the place my kids do homework and other tasks. Thanks to everyone for the tips
Give the dark horse a try: water based poly. I just tried it for the first time over the weekend because I'm tired of my maple turning yellow and it looks just like I've always wanted it to look. Exotics look wet but not oily. I just used Varathane available at HD. Looks great on Sapele too, but probably want to use grain filler like aqua coat. By far the most "natural" finish I've ever had. I'm thinking about taking the whole lot of my oil-based products to hazardous waste disposal and one less fire hazard.
It feels like it's going to be strong but I have no experience here. If it wears faster, just take your ROS to it right in the kitchen once a year and wipe on a new coat. Open a window for 20 minutes and nobody will know.
I have been using counter tops in our kitchen made from Sapele and finished with Arm-R-seal for ~2 years now. My wife loves to cook and we use our kitchen constantly. I have been thrilled with the results. We do not have a single water spot or stain anywhere on the counters, and we do not wipe them dry before bed every night. We actually don't take any special care or treat them any different than we would if they were granite or laminate or anything else.
The protection arm-r-seal has provided has exceeded my expectations. We do have one spot that the finish appears to have been eaten away by some chemical spill (about the size of a quarter) but it was easy to touch up. Not exactly sure what spilled on it to cause that.
I have a blog entry here that shows the construction and finishing process I used.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
