Forum topic by 3285jeff | posted 09-15-2019 12:47 PM | 850 views | 0 times favorited | 9 replies | ![]() |
I just purchased a grizzly go833p table saw which is 220,,,i have 220 but the cord from the table saw is short and I was thinking about making a 10 foot extension cord for it,,,would this be acceptable for the saw,,im sure 12/3 would be the correct size for the wire,,,its not pulling but about 8 amps,,,my question is would it be a loss of power for the saw,,, |
9 replies so far
#1 posted 09-15-2019 01:00 PM |
what size is the wire on the motor now ? for a ten foot extended run, I would replace the wire to the motor. . . -- there is no educational alternative to having a front row seat in the School of Hard Knocks. -- |
#2 posted 09-15-2019 01:11 PM |
What you want to do will work just fine. The saw’s power and performance will be unaffected by it. -- Our village hasn't lost it's idiot, he was elected to congress. |
#3 posted 09-15-2019 03:15 PM |
I’m with John. What you want to do will work. A new cord will get rid of one connection that can over time degrade. And 10 ga will carry the existing load cooler than the 12 gs/ -- Bruce, Boise, ID |
#4 posted 09-15-2019 03:24 PM |
FWIW – 220v line voltage can tolerate 2x longer wiring than 110v, before you get significant power losses with high current devices. Unless the distance between your breaker box and outlet is over ~250ft, there is seldom any concern with reasonable length extension cords on 220v tools. The g0833 manual suggests using a 15A breaker, and 8A FLA. +1 – If you will be permanently adding an extra 10ft of wire, completely replace the existing cord. Cheers! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#5 posted 09-15-2019 09:26 PM |
You have to use a wire gauge based on the breaker you have. You can use a thick wire with a small breaker but it’s a no-no to use a thin wire with a big breaker. According to the NEC a 15A breaker requires 14 AWG wire as a minimum. A 20A breaker requires 12 AWG wire as a minimum, etc. -- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy. |
#6 posted 09-15-2019 09:46 PM |
It is no different than having the permanent wiring 10’ longer. |
#7 posted 09-15-2019 10:25 PM |
I have a 25’ 12/3 wire extension cord that I haven’t needed to use for a permanent placement, but have often used it on tools I am flipping. I can keep the tool right out by the garage door to facilitate easy load out, but anyone coming to try the tool can do so. It works fine, and I can’t see why at 10’ it wouldn’t just have to be temporary. Mostly used for longer runs like house out to detached shop, but easy enough to go shorter, and smaller with it. -- Think safe, be safe |
#8 posted 09-16-2019 01:16 AM |
The NEC requirement you are using applies to permanent building wire, not extension cords and equipment wiring. How many lamps, TV’S, skillsaws, etc. have #12 cords on them being used on a 20A circuit. |
#9 posted 09-16-2019 01:39 AM |
For motor loads, it is a different set of rules when using a starter with overload protection. A single phase 5 HP motor drawing 28 amps on 240 volts will use 10 awg wire, BUT a 60 amp breaker, but a 40 amp time delay fuse, because of the protection from the overloads in the starter. For your motor, drawing 8 amps it is a 1 HP, minimum wire size is 14 with a 15 amp breaker, but 12 amp fuses, but on 120 it would be 16 amps, 14 awg wire, and a 30 amp breaker, but 25 amp fuse. It can get complicated. 12 should be fine, and 10 is better. And for even more confusion, 14 awg is rated for 20 amps, BUT SHALL BE PROTECTED AT 15 amps. And 12 is rated for 25 amps, BUT SHALL BE PROTECTED at 20 amps. |
Forum | Topics |
Woodworking Skill Share
13240 |
Woodturning
2830 |
Woodcarving
578 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6397 |
7940 |
32939 |
CNC Woodworking
334 |
Hand Tools
6487 |
Jigs & Fixtures
1825 |
Wood & Lumber
7309 |
1647 |
Focus on the Workspace
2644 |
1273 |
Woodworking Trade & Swap
5436 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9685 |
