What is causing these black lines in my countertop? A bug?
Forum topic by MitRellim posted 09-12-2019 01:17 PM 350 views 0 times favorited 4 replies Add to Favorites Watch
View MitRellim's profile
MitRellim
2 posts in 8 days
09-12-2019 01:17 PM
Topic tags/keywords: question bugs
I finished these countertops around a month or so ago. A week afterward, I began seeing these black lines. They are producing a bubble on the surface. These countertops were made from century-old wood (I was told Maple). They were finished with five coats of water-based poly. This particular spot is right next to the faucet. The rest of the countertop is fine. Thanks for any ideas and especially solutions!
View WhyMe's profile
WhyMe
1175 posts in 2041 days
#1 posted 09-12-2019 01:36 PM
Did you seal the end grain of the hole that the faucet fits through and also the underside of the top? I suspect moisture has gotten in the wood and mold is growing in the wood.
View SandyK's profile
SandyK
51 posts in 3933 days
#2 posted 09-12-2019 01:42 PM
My guess would be that some water got under the poly, and some mold is growing in there.
I have had water get under poly on an outdoor project which caused the poly to bubble up and turn into a milky white color.
I think I would have used mineral oil for a maple countertop. I’ve heard that you have to put many coats on when new, but less and less over time, similar to a cutting board/butcher block.
-- Sandy, Minnesota, www.rusticwoodworking.com
MitRellim
2 posts in 8 days
#3 posted 09-12-2019 01:49 PM
That makes sense. I didn’t think about sealing the hole, but I imagine that is the case. I will plan to remove the faucet, sand the wood down and hope that I can fix the problem that way.
View controlfreak's profile
controlfreak
144 posts in 82 days
#4 posted 09-12-2019 01:54 PM
Once I saw the proximity to the sink and faucet I had my answer. Sealing the endgrain of the holes would help but in the end water is an insatiable beast and will find a way in. Just think about how often your hands are wet or water splatters onto that area of the counter. I think in the end you will need to have a solid surface around the sink water zone and Maple if you like in the dryer areas. I did do well with mineral oil on an island butcher block surface but had no sink in it. I think slathering oil around the faucet would be a pain in the neck too.
