Powermatic 66 motor bracket,, diy ,used , alternative
Forum topic by dustyguy1 posted 09-12-2019 04:49 AM 159 views 0 times favorited 1 reply Add to Favorites Watch
View dustyguy1's profile
dustyguy1
4 posts in 393 days
09-12-2019 04:49 AM
Topic tags/keywords: powermatic motor 66
So I just picked up a Powermatic 66 for $100. it was an incredible find has original fence on it . There is little bit rusty on the top but salvageable. Ppp but it’s missing the motor bracket looking for some options if anyone’s have any on a bracket I have a motor I’m sure I can source a pulley I have welding abilities can I fabricate a new one has anyone ever done that I don’t look that hard looking for options opinions any help if anyone’s got one and would like to sell or trade
1 reply so far
View CaptainKlutz's profile
CaptainKlutz
1762 posts in 1975 days
#1 posted 09-12-2019 07:07 AM
Are you looking for discontinued part #3480015?
Did you look on fleabay?
Wow, Look what I found….
https://www.ebay.com/itm/Powermatic-66-Table-Saw-Motor-Mount-Bracket-Parts-USA/153637825891
They can be hard to find, and expensive when you do find one.
Totally surprised the one on fleabay popped when i searched?
Have passed on buying a couple cheap PM66 due to motor mounting bracket issues. Story I heard was motor mount tabs/ears would crack/break if blade was stopped violently, or you hard hit motor end hanging outside the machine.
Fabricating a c-face motor mount typically requires machining tolerances for accurate hole placement? If you go that route, might want to start with a Hydraulic Pump-to-Motor Mount for c-face motor. Then cut/weld on new mounting ears? At least that was direction I was considering. YMMV
Best Luck.
