What is this jig???
Forum topic by SoCalBonnie posted 09-11-2019 12:05 AM 1066 views 0 times favorited 16 replies Add to Favorites Watch
View SoCalBonnie's profile
SoCalBonnie
35 posts in 446 days
09-11-2019 12:05 AM
Topic tags/keywords: jig
I got this at an estate sale for $5 because the clamps are worth way more than that.
Before I take it apart I would like to know what it is used for. Maybe I can use it! I’ve searched photos of jigs and haven’t found one that looks like it, except for a cross-cut thingy, which sort of looks like this jig but not really.
What do you think it is? Here is the front:
... here is the side…
...and here is the back…
And should I keep it? Or cannibalize it as originally intended????
16 replies so far
View Lazyman's profile
Lazyman
5228 posts in 2125 days
#1 posted 09-11-2019 12:16 AM
My guess would be a dado jig for a router?
View JohnMcClure's profile
JohnMcClure
992 posts in 1378 days
#2 posted 09-11-2019 12:27 AM
That, or a crosscut/guide jig for a circular saw.
If you have a router or circular saw you could check fit.
Then, cannibalize!
-- I'd rather be a hammer than a nail
View Axis39's profile
Axis39
202 posts in 334 days
#3 posted 09-11-2019 12:33 AM
Could be a planer/jointer/flattening jig for a router as well.
But, I think Lazyman nailed it with a dado jig. Just clamp the workpiece in place, and run the router up the rails.
-- John F. SoCal transplant, chewer uppper of good wood
View Rich's profile
Rich
5535 posts in 1327 days
#4 posted 09-11-2019 12:40 AM
If it was any sort of crosscut jig or dado jig, I’d expect to see marks from the cutting in the fence. Either a kerf from a saw or a wider cut from a router bit. Also what’s the purpose of the groove in the fence? Is it just because they used some scrap wood that had a groove in it, or did some sort of guide ride in it?
You definitely got more than $5 worth of reusable parts with the toggle clamps and even the angle pieces.
bandit571
25596 posts in 3421 days
#5 posted 09-11-2019 12:47 AM
Fancy version of what I would use to cut vinyl siding with….clamps to keep things from moving, while the circular saw did it’s thing.
Lazyman
#6 posted 09-11-2019 12:49 AM
I had the same thoughts about the missing kerf or cutout from the router bit so they either never used it or had another way of stopping the cut. The width of the aluminum looks too far apart for most router bases to me as well.
My first thought was actually a flattening jig but it is made wrong for that. First, it could only be used on boards no thicker than the fences and you would have to move the piece you are flattening instead of the carriage which would not yield a flat top unless the bottom was already perfectly flat.
You may just have to ask Jack since his name is written on it. :-)
View pottz's profile
pottz
9493 posts in 1722 days
#7 posted 09-11-2019 01:57 PM
id just cannibalize and save what you need.a great score for 5 bucks id say.
View DS's profile
DS
3467 posts in 3158 days
#8 posted 09-11-2019 02:08 PM
“It’s like the square root of a million—we may never know.” – Nelson Muntz
View HokieKen's profile
HokieKen
13572 posts in 1876 days
#9 posted 09-11-2019 05:11 PM
“It s like the square root of a million—we may never know.” – Nelson Muntz
- DS
BAHAHAHAHAHAHAHAHAHA!!!
-- Kenny, SW VA, Go Hokies!!!
View MrRon's profile
MrRon
5901 posts in 3981 days
#10 posted 09-11-2019 06:04 PM
Those rails look too far apart for a router. Looks more like a sled for a circular saw, but with the lack of kerf cuts on the cross piece ????
SoCalBonnie
#11 posted 09-11-2019 06:16 PM
- Lazyman
- Rich
Unfortunately, I think Jack was the relative who was supposed to get the jig but who didn’t want it! The people running the estate sale had no idea what it was and it doesn’t fit my circular saw. I’m not sure what the groove is, either… I thought he just used scrap wood to make the jig, but that’s odd because because the rest of the jig is all very nice quality wood.
View MPython's profile
MPython
240 posts in 550 days
#12 posted 09-11-2019 10:08 PM
My guess is a dado jig for a router. The router probably had a purpose-made base, perhaps with UHMW to make it slide easy. I built a similar one for my own use. It works great. Before I chucked it I’d look into building a new router base to fit it. You may find you like it. It looks like a pretty well built jig.
View Knockonit's profile
Knockonit
672 posts in 939 days
#13 posted 09-11-2019 10:38 PM
poor or cheap mans chop saw, hehe, square guide to cut wide material, probably wide shelving jig or siding jig
-- Living the dream
View Andybb's profile
Andybb
2752 posts in 1341 days
#14 posted 09-13-2019 02:04 AM
Probably a one off for a specific project? Keep the clamps and rails and square off the wood and put it in the bin for some future and as yet unknown project.
One of the rare times you can earn the “you suck” tag for something that nobody even knows what it is. :-)
-- Andy - Seattle USA
View WoodenDreams's profile
WoodenDreams
1038 posts in 648 days
#15 posted 09-13-2019 07:43 AM
Looks like you have it upside down, turn it around, then lean it against the wall. It looks like a panel saw for MDF sheets or plywood sheets. lay in a backer board (waste board) between the back and the sheet your cutting. A circular saw is mounted onto a board the slides up and down the to cut the sheet goods. The clamps are to hold the sheets in place once you mark and ready to cut the sheets.
