I Need Tips for Painting Furniture
Forum topic by knotscott posted 09-07-2019 08:43 PM 842 views 0 times favorited 15 replies Add to Favorites Watch
View knotscott's profile
knotscott
8434 posts in 4656 days
09-07-2019 08:43 PM
Hi gang!
I’m making a table for my son and DIL. They want the base painted, and the top wood. I’m going to start with some existing hardwood legs and apron, and only build the top.
I’m looking for tips for finishing and painting the base. The legs are some Asian hardwood with a poly coating. I was figuring on some cleaning and fine sanding to help the primer stick, and would prefer to paint with rattle cans. Sooo….what kind of prep, primer, and paint is best?
15 replies so far
View JohnMcClure's profile
JohnMcClure
1414 posts in 1921 days
#1 posted 09-08-2019 12:17 AM
I use kilz primer for everything but that’s a personal choice. Correct to scuff sand the poly first. I lightly sand between coats of paint with fine grit for that satin feel.
I recommend against rattle cans for the actual paint, likely to be blotchy but ymmv. Good luck!
-- I'd rather be a hammer than a nail
knotscott
#2 posted 09-08-2019 12:19 AM
Thanks John.
Here’s a pic of what it’s supposed to look like.
View wildwoodbybrianjohns's profile
2846 posts in 828 days
#3 posted 09-08-2019 08:17 AM
First thing I would do is determine if the existing finish is water-based or oil-based. The way to tell the difference is to use a clean rag with denatured alchohol on it and wipe a small area, if it glides and doesnt have any effect on the finish, then you have an oil-based product, if it “pulls” and clouds the finish to any degree it is water-based.
Reasoning being, its not good practice to go over a water-based product with an oil-based product.
Whatever product you use for the final finish, if you dont use rattle cans, or dont have a sprayer, and are applying with brushes or rollers combo, it would be good to thin your paint. Penetrol is good for oil-based paints, to extend drying time, reduce brush marks, and the paint will “lay down” better. With water based paint, Flotrol is good, but water is cheaper and has the same result, you can cut by up to 20% with water.
Good luck.
-- WWBBJ: It is better to be interesting and wrong, than boring and right.
knotscott
#4 posted 09-08-2019 12:16 PM
Good info. Thanks much!
View OleGrump's profile
OleGrump
581 posts in 1625 days
#5 posted 09-08-2019 12:45 PM
Hand the spray can over to the kids. They’re the ones who want it painted…...You’re the one who took the time and trouble to MAKE the furniture…... LOL
-- OleGrump
View Lazyman's profile
Lazyman
8185 posts in 2668 days
#6 posted 09-08-2019 01:04 PM
It’s going to be a lot more expensive to paint with rattle cans. For me, the rattle cans are only good if you need 1 or maybe 2 cans for the project. You might look for a Wagner HVLP or even an airless sprayers cheap on FB Marketplace or Craigslist and then you can buy a quart of whatever paint you want for about the same or only slightly more than a single rattle can. I bought a Wagner HVLP for about $25 on closeout at Rockler and it worked very well for spraying some GF Poly on a vintage headboard I refinished. Test any used ones you find with some water at least before you buy it to make sure that it works and still sprays a relatively even pattern. Another option is the famous Harbor Freight HVLP if you have an adequate compressor for it.
#7 posted 09-08-2019 03:46 PM
Hand the spray can over to the kids. They re the ones who want it painted…...
- OleGrump
So very funny!:))
knotscott
#8 posted 09-08-2019 05:51 PM
Hand the spray can over to the kids. They re the ones who want it painted…...You re the one who took the time and trouble to MAKE the furniture…... LOL
- OleGrump
LOL…I want to at least give it chance to look nice when it’s done!
View therealSteveN's profile
therealSteveN
9206 posts in 1855 days
#9 posted 09-08-2019 06:17 PM
Scott it’s really more about the paint you are putting on. Paint either oil, or water based needs a good base to attach to, so some light scuffing of the existing is a good start. I too like Kilz as a primer, then spend some $$$$ on the paint, and at that point the better stuff is fully self leveling, so you can apply with a brush, and get a good final result.
I used to use Behr paint, and felt it was very good, but I don’t do Home Cheapo anymore so at Menards I have been Using Pittsburgh Platinum, it’s better than the Behr IMHO. Truly one coat coverage, and I always use a brush with paint, and on first stroke, you think, ohhh lookit those streaks. In 30 seconds they are gone, and then you are just doing that mental thing, it doesn’t look like the paint chip….. Of course once it dries it does.
-- Think safe, be safe
knotscott
#10 posted 09-08-2019 07:45 PM
Thanks to all for the help.
Here’s where I’m at so far. I did the denatured alcohol test, and determined that the finish is oil base on both the legs and chairs. As a test, I lightly sanded and cleaned one of the chairs, and gave it 2 coats of Krylon Colormaxx paint & primer, with a light high grit sanding between coats. Looks pretty good so far.
Would it be beneficial to apply a clear coat for protection? If so, what should I use over the Krylon?
7284 posts in 3774 days
#11 posted 09-08-2019 07:51 PM
My opinion is the paint itself is plenty durable. So I don’t see any advantage to a clear overcoat.
#12 posted 09-08-2019 11:26 PM
+1 on previous post from Fred. No need for clearcoat.
View Joe Lyddon's profile
Joe Lyddon
10963 posts in 5333 days
#13 posted 09-09-2019 10:55 PM
Deft makes some good Colored Lacquer based rattle cans…
Super good…
IMHO…
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php?media/albums/users/joe-lyddon.1389/
therealSteveN
#14 posted 09-10-2019 08:35 AM
I am also in the no need to clear coat a painted surface. Fixing a clear coat over paint is a tough fix. Fixing a painted surface is as easy as applying another coat.
Most of those who use a clear coat over paint are wanting a glossier look. Buy gloss base for the paint.
Let what you have set for a day or 3, see if you like it?
knotscott
#15 posted 09-10-2019 12:15 PM
Great advice. Thanks guys.
