Does anyone have experience with using Alder?
Forum topic by Ccl2011 posted 09-05-2019 06:35 AM 1258 views 0 times favorited 31 replies Add to Favorites Watch
View Ccl2011's profile
Ccl2011
14 posts in 2179 days
09-05-2019 06:35 AM
Topic tags/keywords: wood
Hi,
I recently got stationed in Okinawa, Japan and am now using the base wood shops where the cheapest material is rustic alder at $1.75/BF.
I’ve never used alder before and was wondering if anyone had suggestions as to pros and cons of it for small projects (end tables, stools, etc.)
I’d appreciate any feedback.
Thanks, Chris
31 replies so far
View RDan's profile
RDan
165 posts in 3244 days
#1 posted 09-05-2019 07:12 AM
Chris, I live in WI near the Twin Cities, MN Adler is one of the woods used for interior trim, doors and cabinetry. I have not worked it, but it is a softer wood that takes stain well. Many around here have what is called Knotty Adler for a more rustic look. Your cost is very reasonable. Have fun, enjoy your time on the Rock. Dan (USAF Kadena AB 1980-81. Retired USAFR SMSgt)
View CaptainKlutz's profile
CaptainKlutz
3842 posts in 2414 days
#2 posted 09-05-2019 08:28 AM
Have used it some?
Alder is often call poor man’s cherry. It’s close to same hardness, just a little softer.
It takes stain just like cherry, which means you have to watch for blotching issues on grain changes. Rustic/knotty alder is worst for botch. It machines and sands easily. Can burn edges just like cherry or maple if tools are dull, or binding during a cut.
I use it regularly for jig/fixtures, and painted furniture instead of other cheap wood choices.
Personally dislike using alder for keepsake furniture. If I will spend weeks/months building something that I want to last, spending more for higher quality wood is always worth it.
Why dislike alder furniture?
The grain is muted, and rarely has any figure unless rustic style. When it does show figure, you get tear out very easy. Has a boring cream/off white color; and only change is slight grey tint as it ages. So any clear finish that turns more amber over time, just pushes the color towards yellow-grey yuk. Another challenge is cost of Alder veneer plywood is ridiculous. Can get maple/oak veneer for 60-65%% of what alder ply costs. For any large box project, any savings using cheap alder wood is lost on matching plywood.
Can get #3 common 4/4 rustic alder for ~ $1 bdft here in AZ, due high volume of culled material from several local cabinet/custom shops using it. Even FAS Alder is only $2.50 bdft. Local shops like it as can be stained to look like most any wood to the uneducated. It comes from CA/OR/WA forest which makes it cheaper than east coast domestic lumber choices. Plus it looks better than popular, or various softwoods.
One local place has a plethora of color options as examples of what can done with Alder:
https://stonecreekfurniture.com/styles/
My finishing supplier tells me they spray and rub out Mohawk Ultra Penetrating (dye) Stains for their colors, after applying a vinyl sealer for botch control. I use same stains and spray/rub method on alder, but use blonde shellac for botch control.
Only alder I think looks nice is spalted alder. It’s not common, but it looks great on small boxes and such.
http://hobbithouseinc.com/personal/woodpics/alder.htm
BTW – During the building boom in SW US ~10 years ago, common grades of alder were milled and sold in construction lumber sizes (2×4, 2×6, 2×8, etc). For almost 2 years, alder was same price as Douglas fir construction lumber due shortages and price increases on softwoods. Several custom home builders have continued to use alder even as softwood prices lowered back to normal, as high end hardwood lumber selling point. Only mention alder use as building material to point out the utilitarian nature of the wood.
Thanks for your service.
PS – My cousin in Navy is based out of Okinawa right now. Small world?
Best Luck working wood in Japan!
View Lazyman's profile
Lazyman
5968 posts in 2307 days
#3 posted 09-05-2019 12:07 PM
You may be seeing Japanese alder or another species from Asia over there rather than red Alder which is the most common species in the US so it could have different qualities than what we see over here. You may just have to experiment with it to see how well it works.
View avsmusic1's profile
avsmusic1
674 posts in 1605 days
#4 posted 09-05-2019 01:08 PM
Where is thefridge?
View waho6o9's profile
waho6o9
8954 posts in 3497 days
#5 posted 09-05-2019 01:36 PM
Thank you for your service.
View pottz's profile
pottz
12402 posts in 1904 days
#6 posted 09-05-2019 02:45 PM
i made a set of desks and book cases out of alder a few years ago,real nice to work with and machines easily.i just like to put an oil finish on it because i love the natural color and rustic look.as mentioned what your getting is probably not the red alder we have here in the states.also thank you for your service.
View d_sinsley's profile
d_sinsley
202 posts in 475 days
#7 posted 09-05-2019 03:03 PM
I actually really like alder. I second it being similar to cherry. It can be a very pretty wood with some nice grain. Depending on what you are doing there is rustic alder which kinda has a hickory feel to it. But most alder is very straight grained, at least the stuff I have used.
-- Devon
View jmartel's profile
jmartel
9111 posts in 3070 days
#8 posted 09-05-2019 03:55 PM
Have used it some?
Alder is often call poor man s cherry. It s close to same hardness, just a little softer.
- CaptainKlutz
Not even close to the same hardness. Alder is extremely soft. Alder has a Janka Hardness of 590 and Cherry is at 950. It’s only mildly harder than Poplar, for instance.
View LesB's profile
LesB
2678 posts in 4363 days
#9 posted 09-06-2019 11:23 PM
Someone mentioned the Fridge. In Alaska Alder is a bush variety and grows in almost impenetrable thickets. Further south there is the fast growing tree variety and it is a great “soft” wood used for a variety of things. Just be aware it “dents” easily so for table and counter tops it will not hold up well.
-- Les B, Oregon
View AlaskaGuy's profile
AlaskaGuy
6221 posts in 3229 days
#10 posted 09-07-2019 12:04 AM
- RDan
Stains well??? here’s some stained alder. I have to disagree.
View LeeRoyMan's profile
LeeRoyMan
1444 posts in 647 days
#11 posted 09-07-2019 12:59 AM
I’ve done many many projects with Alder. Somethings look more blotchy than others, but I’m ok with it, just looks natural to me.
LeeRoyMan
#12 posted 09-07-2019 01:04 AM
View Snipes's profile
Snipes
459 posts in 3164 days
#13 posted 09-07-2019 04:12 AM
Nice projects Leroy! Look good from here
-- if it is to be it is up to me
View WoodenDreams's profile
WoodenDreams
1185 posts in 831 days
#14 posted 09-07-2019 06:00 AM
The only time I made something with Alder, was two years ago. It was a 24”x60” wall table with a 20”x56” lower shelf for a CPA. She wanted a wall table to spread out the tax returns that she prepares for clients. The Alder was very easy to work with. When it came to staining, blotching was a issue to me. I delivered it to her to get a her thoughts and she actually loved the appearance of the blotching. and said I should have charged her more for the table. I was satisfied to have a happy customer.
View rustfever's profile
rustfever
797 posts in 4230 days
#15 posted 09-07-2019 01:22 PM
Western Red Alder is native to the Pacific Northwest of the US, Canada, and Alaska. It is a easy to use wood for various projects. It is a bit on the soft side, so it is not advised for project subject to heavy wear/abuse. It is easy to shape/cut/mill. It sometime is a bit challenging to get it to stain, but when mastered,produces very nice finish.
The wood is frequently used commercially in upholstered furniture [sofas, chairs, etc] and some lighter duty desks.
-- Rustfever, Central California
showing 1 through 15 of 31 replies
