Stanley 78 bent casting. Worth fixing?
« back to Hand Tools forum
Forum topic by AESamuel posted 09-02-2019 09:59 AM 566 views 0 times favorited 11 replies Add to Favorites Watch
View AESamuel's profile
AESamuel
105 posts in 2028 days
09-02-2019 09:59 AM
I have an old stanley 78 plane that has a sideways curve along it’s length, I measured the gap with a straight edge and it came out 0.4mm/1/64th”. The opposite side has the curve the opposite way so it seems the casting above the main blade bed is bent.
The plane is in otherwise reasonable condition and other than the bend, wouldn’t require much work to get a nice user. So my question is, having no investment in the plane, is it worth trying to fix? If so, what would be the best way to go about fixing the bend?
If not, I might just convert it to a scrub plane à la Paul Sellers.
Thanks for any advice!
11 replies so far
View Don W's profile
Don W
19652 posts in 3373 days
#1 posted 09-02-2019 12:22 PM
80 grit sand paper on a flat surface. 1/64 will come out quick.
View Tim's profile
Tim
3859 posts in 2767 days
#2 posted 09-02-2019 05:25 PM
I agree, that shouldn’t be too hard to get into decent shape. If you’re going to spend time on it you may want to see how square the sole is to the sides. 78s were never as accurately square that way as finer set shoulder planes, but if you can get it square it should be useful for more things.
View theoldfart's profile
theoldfart
11804 posts in 3257 days
#3 posted 09-02-2019 07:39 PM
If the above doesn’t work out PM me, I have a 78 body you can have for postage.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View MrRon's profile
MrRon
5925 posts in 4049 days
#4 posted 09-03-2019 12:07 AM
That gap looks more than 1/64”, more like 1/32”. Even if you could remove that amount of material from both sides, the slot would still not be 90° to the side of the plane. I think that plane is a lost cause. Take up the oldfart’s offer.
View farmfromkansas's profile
farmfromkansas
210 posts in 420 days
#5 posted 09-03-2019 01:57 AM
Would you be out anything if you broke the casting? If not, take a couple steel blocks and a big hammer and set it up on the blocks, and smack it on the high side. If it is made of cast steel, might be able to straighten it.
View JayT's profile
JayT
6402 posts in 3017 days
#6 posted 09-03-2019 11:02 AM
- farmfromkansas
It’s cast iron, so that would just break it. There’s no way it “bent”, either—I’d place a bet on it just being a bad casting.
Follow Don’s advice and flatten. The left side will flatten easily, due to how little surface area is on that side. while the right will take a bit longer. It’s still possible and a simple process, just requiring a bit of time and patience.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View Eric's profile
Eric
212 posts in 1043 days
#7 posted 09-03-2019 01:00 PM
Probably was dropped. If you have a 48×6 belt grinder you can flatten it quickly.
-- Eric
AESamuel
#8 posted 09-03-2019 02:56 PM
Thanks for the replies everyone. I’ll have a go with some sandpaper and see what I can do. Like I said I haven’t got an investment in it so I won’t spend too long on it.
My first thought was the hammer trick as I have used that for plane irons before but I’m glad I didn’t try it and crack it straight away.
Theoldfart – thanks a lot for the offer but I’m in the UK so postage might be a bit too much. Much appreciated though!
View Bill White's profile
Bill White
5294 posts in 4766 days
#9 posted 09-03-2019 04:24 PM
Belt sander, surface grinder, hand sand. Mouth would not be that big an issue.
-- [email protected]
View corelz125's profile
corelz125
1413 posts in 1782 days
#10 posted 09-03-2019 07:46 PM
Steel blocks and a big hammer haha it would be a #78 pinata
View Andybb's profile
Andybb
2784 posts in 1409 days
#11 posted 09-04-2019 10:35 PM
Take up the oldfart s offer.
- MrRon
+1
-- Andy - Seattle USA
