Harbor Freight 10x18 lathe (65345) belt swap
« back to Woodturning forum
Forum topic by RedTower43 posted 08-31-2019 01:47 PM 483 views 0 times favorited 7 replies Add to Favorites Watch
View RedTower43's profile
RedTower43
3 posts in 76 days
08-31-2019 01:47 PM
Topic tags/keywords: question lathe spindle belt change
Hi all, first post here. I did a lot of looking and haven’t found any useful answers so here goes nothing.
I recently decided to put a new belt on my lathe (harbor freight 10×18, 65345). The stock belt is a few years old and stretched out. There are only a couple videos on the process but it looked pretty straight forward. In order to install the new belt, you have to partially remove the spindle by removing the wheel from the end and loosening the allen screw that secures the pulley to the shaft. Then the spindle should (in theory) be removable. There seem to be a couple methods of doing this. In one video the left the headstock on the lathe and beat it out with a rubber mallet. In another, they removed the headstock and used a set of clamps to apply pressure and gently tap it loose.
I’ve tried both and neither have worked. It’s really, really stuck in there. There seems to be a bit of rust between the bearing and the hole it’s seated in. That is probably the culprit. I’m letting some WD-40 sit it for a bit to see if that will help break it loose.
Has anyone here had this much trouble with a belt change on this machine and if so do you have any tips for getting the spindle out? Thanks in advance.
7 replies so far
View WhyMe's profile
WhyMe
1182 posts in 2097 days
#1 posted 08-31-2019 02:13 PM
The bar clamp isn’t going to cut it for pressing out the shaft. You are going to need to whack it with a mallet.
RedTower43
3 posts in 76 days
#2 posted 08-31-2019 02:41 PM
Yeah I know. The second video I saw used a similar set up and then tapped the clamp with a mallet. I’ve also tried just beating it directly. Neither method has budged it.
View WoodenDreams's profile
WoodenDreams
791 posts in 447 days
#3 posted 08-31-2019 04:52 PM
I’m interested. Let us know what worked for you. Looks like your using a ‘Tool Shop’ F-clamp. Bought 12 of them on sale and had to return six of them for exchange since the kept slipping when clamping down. So now I won’t buy anymore of them and I now only try using the ‘Tool Shop’ brand if my other brand clamps are all in use.
WhyMe
#4 posted 08-31-2019 08:41 PM
Are there any snap rings that you may not be noticing?
Edit: Parts diagram shows retainer rings.
Watched video and definitely you just knock the shaft out. Retainer rings are holding bearings only.
RedTower43
3 posts in 76 days
#5 posted 08-31-2019 08:59 PM
- WhyMe
None that I saw.
I m interested. Let us know what worked for you. Looks like your using a Tool Shop F-clamp. Bought 12 of them on sale and had to return six of them for exchange since the kept slipping when clamping down. So now I won t buy anymore of them and I now only try using the Tool Shop brand if my other brand clamps are all in use.
- WoodenDreams
Yeah tool shop anything is pretty terrible. I bought before I knew better but they’re all I have with a deep enough throat.
I gave up for now and stuck with the old belt. I plan on buying a new lathe next tax season so I’ll make due until then.
View bandit571's profile
bandit571
23965 posts in 3220 days
#6 posted 09-01-2019 12:41 AM
You could just cut the belt, and use a link belt instead, connect the ends after the link belt has been threaded through. can get a link belt at Harbor Freight, too.
MrUnix
7502 posts in 2735 days
#7 posted 09-01-2019 02:47 AM
As mentioned, that “F” clamp isn’t ideal, and a rubber mallet is just about as bad. For tapping it out – from my experience – you want at least a soft-blow hammer or a regular hammer and a piece of wood between it and the spindle.
If the spindle is hollow, then another way is to make a cheap spindle puller using all-thread and a couple of other bits and pieces:
