What would you call this?
Forum topic by Derrick posted 08-29-2019 09:34 PM 642 views 0 times favorited 14 replies Add to Favorites Watch
View Derrick's profile
Derrick
221 posts in 2152 days
08-29-2019 09:34 PM
I’ve been slowly rebuilding my jointer. It’s a Dayton 8” that I got off of CL for free, a few years back. It’s a copy of many other 8” jointers. Originally it was sold through Grainger.
Anyhow,
The motor mounting assembly has a busted “tension rod”, and I’m looking to replace it.
#11 in this pick:
Is there another name for these items? I was thinking “eye bolt”, but the ones I’m seeing are same size threaded portion as the hole of the eye.
The hole is roughly 3/4”. The shank is roughly 1/2”.
I was also thinking ‘“rod end”, but that hasn’t turned anything up either.
Does anyone have any ideas?
Thank you.
Derrick
14 replies so far
View Ocelot's profile
Ocelot
2894 posts in 3652 days
#1 posted 08-29-2019 09:38 PM
Looks like something a welder could make.
-- I intended to be a woodworker, but turned into a tool and lumber collector.
Derrick
#2 posted 08-29-2019 09:44 PM
- Ocelot
True. I’ll consider that if I can’t find it. I’m assuming the broken threaded portion could be cut off, and a piece of all thread could be attached.
I just don’t really want to spend 50-75$ for the hour if I can find one for under 20$.
View rickinbeachcrest's profile
rickinbeachcrest
16 posts in 2496 days
#3 posted 08-29-2019 09:47 PM
Looks like a relatively simple piece to fabricate. Some 1/2” all thread and a piece of 3/4” inside diameter tubing. Weld the two together and you’ve got it.
I think trying to find this part would be almost impossible.
Maybe a good excuse to buy a small MIG welder. Nothing like the ability to join two pieces of steel.
View bigJohninvegas's profile
bigJohninvegas
946 posts in 2476 days
#4 posted 08-29-2019 10:47 PM
So I would find the right all thread, or a long enough bolt. Often a bolt won’t have the full length threads.
Cut it to the proper length. Grind off the broken threaded piece to reuse the tubing section.
Find a welder. It’s about a minute of welding work if you have the parts prepared.
Case of beer, or lunch goes a long way.
Better yet, I have made some cool bottle openers that have made good trade items for this sort of thing.
-- John
View ibewjon's profile
ibewjon
2278 posts in 3807 days
#5 posted 08-29-2019 11:40 PM
Or if you have clearance, cut the rod shorter and add a rod coupling and some more rod.
View LeeRoyMan's profile
LeeRoyMan
1544 posts in 741 days
#6 posted 08-29-2019 11:45 PM
How about a connector bolt.
Put the 2 pieces back together.
View MSquared's profile
MSquared
1152 posts in 928 days
#7 posted 08-30-2019 12:17 AM
All good suggestions. I’d go with the welder, fabricator, or body shop. The first two may/probably gonna be pricey. Prep the pieces for whomever and they’ll whip it up. Beer, Lunch, usually are appreciated as a good will gesture. Present the beer on ice, with chips or pretzels! ;) ( In my case, I barter with my Mechanic with BBQ Ribs, and they give me excellent craft Homebrew aside from free repair advice!) Plus, you’ll establish a good connection. Or, as Rick said, try your hand at MIG welding. A few bucks spent at HF for a rig (not too shabby for amateurs, from what the pros tell me) and it’s good for a thousand uses! Youtube! Pros go there too.
-- Marty, Long Island, NY
ibewjon
#8 posted 08-30-2019 02:27 AM
Connector bolt? That is a picture of a rod coupling that I mentioned earlier.
View Knockonit's profile
Knockonit
769 posts in 1216 days
#9 posted 08-30-2019 02:34 AM
i think they are labeled a “trunion adjusting bolt”
-- Living the dream
LeeRoyMan
#10 posted 08-30-2019 02:40 AM
- ibewjon
So I called it by a wrong name?, that’s why I put up the picture,
Your mention earlier was only a few minutes ahead of me. I was typing when you posted.
Derrick
#11 posted 08-30-2019 02:44 AM
I considered the coupler as well. I was just hoping this was an easy part to source.
Looks like I was wrong.
View CaptainKlutz's profile (online now)
CaptainKlutz
4180 posts in 2508 days
#12 posted 08-30-2019 08:10 AM
Have seen that same adjustment method and bolt on the 15” planers I rebuilt that have motor in cabinet below the machine?
Does this Grizzly P1021 planer part work?
https://www.grizzly.com/parts/Grizzly-ROD-END-BOLT-M10-1-5-X-100-ID-16-5MM/P1021X2154
Update: FWIW -The g1021 tool is made in Taiwan. The G0453 is made in China by different mfg and uses two of those style bolts.
https://www.grizzly.com/parts/Grizzly-ADJUST-BOLT/P0453433
Also a good bet that if machine came from Asia after 1970, the fasteners and rods are metric.
Cheers!
Derrick
#13 posted 08-30-2019 01:21 PM
Cheers!
- CaptainKlutz
I think we have a Winner! If not, we’re really close! Since my jointer is a knockoff, I was hoping the part existed on another model.
Thank you to everyone who responded!!
View bgood's profile
bgood
38 posts in 740 days
#14 posted 09-01-2019 04:21 AM
I’ll TIG one for you.
Send me the sleeve.
PM me.
