Danish Oil - Laquer - Mess - Q
Forum topic by unclearthur posted 08-28-2019 07:11 PM 505 views 0 times favorited 7 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
385 posts in 2874 days
08-28-2019 07:11 PM
I finished a small item with Danish Oil, and then next day on impulse sprayed it with some Watco spray lacquer I had around.
Now a day later, the item is very tacky / sticky basically gross. I tried to rub it with a little steel wool, bit its not helping.
Any suggestions to fix? The lacquer can says to clean-up with lacquer thinner – but I’m not sure what that is and I don’t have any. I do have mineral spirits and acetone.
Thanks for any suggestions.
7 replies so far
View Rich's profile
Rich
6851 posts in 1676 days
#1 posted 08-28-2019 07:31 PM
Any suggestions to fix? The lacquer can says to clean-up with lacquer thinner – but I m not sure what that is and I don t have any. I do have mineral spirits and acetone.
- unclearthur
Acetone will remove lacquer.
unclearthur
#2 posted 08-28-2019 07:37 PM
Thanks Rich, will try.
View wildwoodbybrianjohns's profile
2764 posts in 634 days
#3 posted 08-28-2019 07:47 PM
Yep, agree with Rich, strip it with acetone. Danish oil is basically linseed oil, next time, apply, wipe it off best you can, give it time to dry, like 3 days or so, maybe even sand with a fine grit before lacquering, should be ok.
-- WWBBJ: It is better to be interesting and wrong, than boring and right.
View EarlS's profile
EarlS
4463 posts in 3435 days
#4 posted 08-28-2019 07:47 PM
As I recall, danish oil takes something like 72 hours to cure/dry before applying anything on top of it. Set it outside in the sun after stripping off the lacquer to let it dry out.
unclearthur
#5 posted 08-28-2019 08:45 PM
Thanks. No more acting on impulse.
View MrUnix's profile
MrUnix
8567 posts in 3286 days
#6 posted 08-28-2019 10:04 PM
- EarlS
Yup, at least the Watco stuff does – sez right on the container. I always give 3 days minimum before I finish with poly. – longer if I can get away with it.
View TungOil's profile
TungOil
1383 posts in 1582 days
#7 posted 08-31-2019 01:49 AM
After you strip off the lacquer, You might want to seal the danish oil with dewaxed shellac before topcoating. Zinser Sealcoat works well. Shellac is a good intermediate finish to apply between incompatible finishes.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
