Turning a two axis piece
« back to Woodturning forum
Forum topic by Jim Jakosh posted 08-27-2019 02:58 PM 650 views 0 times favorited 11 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
23609 posts in 3670 days
08-27-2019 02:58 PM
Topic tags/keywords: resource
I had been asked to do a video on how I had turned some similar pieces and I’m not set up to do it by myself in the shop so I made a bunch of still shots to convey the idea of how to do it. Rudy Lopez demonstrates this in his program and this video: ( https://www.youtube.com/watch?v=84Oh04ZT8tE&t=939s )
Here is how I did it.
I first rounded up a log and marked it off for wire burned grooves every half inch. The detail you put on the sides is up to you. Rudy uses beads and I did burned grooves.
Then I used my index wheel and drill fixture to center drill two holee exactly opposite each other on the center of the piece. and I drilled a 3/16” hole for my drive center in one of them
I mounted the round stock between center sin those holes and turned a spigot on one side. I put the live center in the side with the bark because I was going to turn it all away. I shaped the outside on this piece with a recurve…in order to take away the place where some wood had chipped out
The I held it by the spigot and started turning away the inside to follow that outside curve. I spin it at 1400 to 1600 rpm to get a cleaner cut.
I mount it on a jam chuck to finish the bottom.
I don’t do any sanding on the lathe for obvious reasons and I use a Harbor Freight 90 degree drill with Klingspor scalloped sanding discs to finish sand all the areas and clean it up
Cheers, Jim
11 replies so far
View lew's profile
lew
12901 posts in 4320 days
#1 posted 08-27-2019 11:34 PM
Thanks for the tutorial, Jim!
View Joe Lyddon's profile
Joe Lyddon
10809 posts in 4617 days
#2 posted 08-28-2019 12:18 AM
That looks SO SCARY to me… I don’t think it would be worth the effort / chance…
GOOD LUCK…
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php
View mike02719's profile
mike02719
175 posts in 4350 days
#3 posted 08-28-2019 02:06 PM
Very creative, This presents lots of possibilities for me. You did not mention what species of wood you used unless I missed it. I will surly give your method a try. Thanks
-- Mike, Massachusetts
Jim Jakosh
#4 posted 08-28-2019 05:24 PM
Thanks Lew and Joe!
Hi Mike. That wood is maple and it was cut about 5 weeks ago but it was pretty dry when I finished it.
I think a real dry wood might be a problem with chipping on the thin edges that are left. I got minimal chipping but it did a little anyway. You have spin it fast and they it turns like it is a solid piece almost. I watched Rudy Lopez’s video and he adjusted his tool rest with the part spinning and that is something I teach the kids never to do…especially with square edges or wings flying around. I make it habit to stop the part when making any adjustment to the tool rest.
cheers, Jim
View doubleDD's profile
doubleDD
8812 posts in 2608 days
#5 posted 08-30-2019 12:31 AM
Thanks Jim, that will me in future turnings. Always good to see how people do things.
View Redoak49's profile
Redoak49
4283 posts in 2553 days
#6 posted 09-01-2019 10:58 AM
Very nice but would scare me to turn.
Jim Jakosh
#7 posted 09-01-2019 12:28 PM
Thanks, Redoak49!! I don’t drink any beer while turning one like this!
Cheers, Jim
View Nubsnstubs's profile (online now)
Nubsnstubs
1635 posts in 2294 days
#8 posted 09-01-2019 01:27 PM
Thanks for posting, Jim. I have done a lot of wings, but always use natural logs to keep it a natural. I guess I’ll have to do one similar to this because I’m not scared to give it a try. Also, when any type of alcohol touches my lips, I’m done for the day, usually about 4 pm…...Never mix alcohol and liquor with cutting machinery….... Fingerless Jerry (in Tucson)
Jim Jakosh
#9 posted 09-01-2019 03:30 PM
Hi Jerry. I tried one of these with the bark on, but it chips off in many places when the edges gets thin so I gave up on trying any more. I even get chipping on one of these with the OD already rounded up!
cheers, Jim
25847 posts in 4416 days
#10 posted 09-03-2019 03:42 AM
Great blog & great result Jim.
Jim Jakosh
#11 posted 09-03-2019 08:48 PM
Thanks, Tony. I had been asked before to show how I did it, so I took the camera out the barn at the start of it!
Cheers, Jim
