Gluing Small Plywood Pieces onto a Larger Plywood Panel
Forum topic by PresidentsDad posted 08-23-2019 01:46 AM 294 views 0 times favorited 3 replies Add to Favorites Watch
View PresidentsDad's profile
PresidentsDad
57 posts in 726 days
08-23-2019 01:46 AM
Hey All,
I’ve got a project going where I need to glue some small pieces of plywood (like 1.5” x .75” x .5”) on end (aka edge) to a larger piece of plywood (that is .25” thick). These will act as stops for some semi small parts storage (like thin table legs). My question: Is wood glue enough for this? What about CA glue? In either case, do I need pin nails? Thanks in advance for your assistance!
3 replies so far
View Kelp's profile
Kelp
5 posts in 25 days
#1 posted 08-23-2019 02:07 AM
Edge to edge or edge to face? It sounds like edge to face, in which case do you have access to the backside? I would personally do wood glue with a brad nail through the back. Can you provide a picture of them mocked up?
PresidentsDad
#2 posted 08-23-2019 03:21 AM
Diagrams I have for the build are copyrighted, so probably not, but think of standing up a small piece of plywood where the edge (where the layers are) are glued to the face of the larger piece of plywood. I do have access to the backside.
- Kelp
View Rich's profile
Rich
4804 posts in 1068 days
#3 posted 08-23-2019 03:30 AM
The edge of plywood is basically 50% long grain, so gluing to the face of plywood will be a strong joint. When I put together jigs, etc, I often use pin nails. Not so much for strength, but to keep the pieces in place while I clamp them.
-- There's no such thing as a careless electrician
