Modify router insert rings for dust collection?
Forum topic by scribble posted 08-22-2019 05:26 PM 223 views 0 times favorited 5 replies Add to Favorites Watch
View scribble's profile
scribble
216 posts in 2680 days
08-22-2019 05:26 PM
Topic tags/keywords: question router
I am wondering if anyone has modified there plastic router plate inserts similiar to the Incra clean sweep metal plates are like for better dust collection. I recently built NYW router table and most dust gets pulled in when doing edge routing but when cutting dado’s or the like it just pushes all the dust off the edge of the table.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
5 replies so far
View Andybb's profile
Andybb
2024 posts in 1082 days
#1 posted 08-22-2019 11:42 PM
Depending on the job at hand I either use an under the table setup to pull dust down or one on the fence to pull dust in. My under the table system consists of a large rectangular plastic bin with a hole in it that fits my shop vac hose and is bungee corded to the bottom of the table. (an insert in my table saw)
-- Andy - Seattle USA
5683 posts in 2972 days
#2 posted 08-23-2019 05:08 PM
I’m speculating, but it seems to me that the workpiece will cover almost all the extra opening area. If true, it hard to imagine how that would do much to help with the collection. You might try using an insert with the next-size-up opening…that’s just to test whether the extra open space helps.
scribble
#3 posted 08-23-2019 05:51 PM
If any one has seen the Incra cleansweep system you will see what I am describing.
Andybb
#4 posted 08-23-2019 05:55 PM
I’ve seen that but as Fred said above I’d just try using an insert with a larger opening.
View d38's profile
d38
134 posts in 741 days
#5 posted 08-26-2019 03:39 PM
I have the Incra Clean Sweep and its awesome for dado cuts and edge cuts.
I agree with Fred and Andy, on a dado cut, try a bigger insert. Generally we’re using longer boards on dado cuts, so the board doesn’t need as much support.
Of course, if your table has the same plate size as the Incra, its an awesome upgrade.
But if your inserts have plenty of material, drill some holes and/or use a scroll or jig saw to make some holes.
