need tool advice
Forum topic by Karda posted 08-19-2019 03:21 AM 356 views 0 times favorited 13 replies Add to Favorites Watch
View Karda's profile
Karda
1644 posts in 1033 days
08-19-2019 03:21 AM
Hi, I have a HF belt sander. I want to mount a grinder tool rest on the grinder so I can platform sharpen my wood turning tools Here is a pic of the sander and the tool rest. Thanks Mike
13 replies so far
View Lazyman's profile
Lazyman
3873 posts in 1866 days
#1 posted 08-19-2019 03:45 AM
You may need to show us more of the sanders’s base and and views angled from the sides to get some advice.
It probably has or had a rest that comes across the belt? It might be easier to just attach a pivoting platform to the same attachment point as the old rest rest?
View bandit571's profile
bandit571
23589 posts in 3162 days
#2 posted 08-19-2019 04:14 AM
Hmmm, I have a Craftsman version. It had a platform that slides onto a steel rod…can be used either with the disc sander, or change the rod’s location, and it will work with the beltsander part…Has a scale for degrees,too…
Maybe later today (Monday..) i can get a few photos?
Karda
#3 posted 08-19-2019 06:19 AM
he are pics of the sides. The hex bolt in the 1st pic fastens the tool rest to the sander. I tried to use it for a base but it fastrens only on one side an was not stable. Bandit this sander has a table like you picture but is to wide to use for platform sharpening. I tried to think of a way to use it but I’m not that creative. I’ll post pics of that tomorrow.
Lazyman
#4 posted 08-19-2019 02:49 PM
Assuming that there is room behind the platen and nothing moving that would interfere, how about drilling a hole on the opposite side so you can attach from both sides, Even better, Drill another hole on both sides about 2 inches higher so that it won’t pivot. Attach a triangular brackets with long bolts on both sides. Remove the platform from the tool rest you want to use and attach it to the brackets in a way that will allow you to tighten it down. If it is not wide enough, you might have to have a spacer on one or both sides so that it clamps it down when you tighten the lever bolt shown in your picture (might require a longer bolt as well.
Not sure my description makes sense. I think that I showed you this before but you can see a similar solution on my blog about the belt sander I built here.
Karda
#5 posted 08-19-2019 05:02 PM
Hi, there is nothing behind the platen so I can drill. I was wondering about a bar across the belt. I can remove the articulating arms of the rest from the base. The only thing is it .25” would that be stable enough. I noticed the rest you made is only attached to the sander on 1 side only is that stable.
I was looking at my table and was thinking about a bracket that would fasten in where the table mounts. But would that be stable enough being that long. Here are the pics of my table. I think you did send me some plans. I lost my documents a while back and that was in there
View Ocelot's profile
Ocelot
2323 posts in 3117 days
#6 posted 08-19-2019 07:52 PM
This has been done and written up already – very nicely written up here and in a magazine article.
I’ll see if I can find it.
-Paul
Ocelot
#7 posted 08-19-2019 07:59 PM
Karda
#8 posted 08-26-2019 11:05 PM
Hi i came up wiuth a rig that I think will work. It isn’t pretty but I think it will work. I have it set to 40 degrees. Now all i need is the proper grit belt
bandit571
#9 posted 08-26-2019 11:30 PM
he are pics of the sides. The hex bolt in the 1st pic fastens the tool rest to the sander. I tried to use it for a base but it fastrens only on one side an was not stable. Bandit this sander has a table like you picture but is to wide to use for platform sharpening. I tried to think of a way to use it but I m not that creative. I ll post pics of that tomorrow.
- Karda
In the first photo…the bracket with the hex head bolt,,,is that a hole for the rod from the fence to go through, then use the head head to tighten/ lock the table in place? If so, you might give it a try…
On mine, there is such a hole….the rod is inserted through it, and a bolt secures it in place…
Karda
#10 posted 08-26-2019 11:40 PM
yes there is a bold holding the legs to the base. I was thinking of a bracket across the front of the belt but it would be thin, the bolt is 6MM. I would have to drill and tap a holes for the bracket and i don’t have the tools. I would have to remove the bracket to change the belt. i made the stand I made with scrap wood and need no additional tools. If it does the job I want I will improve it.
View Jim Finn's profile
Jim Finn
2737 posts in 3401 days
#11 posted 08-27-2019 01:27 AM
I have two of these Harbor Freight sanders and both have a stop that can be adjusted to an angle. These are the most used tools in my shop and work very well.
-- No PHD just a DD214
View HorizontalMike's profile
HorizontalMike
7796 posts in 3393 days
#12 posted 08-27-2019 10:59 AM
Here Karda, check out my review on how to make decent jigs using the HF belt sander, for sharpening:
https://www.lumberjocks.com/reviews/3179
Karda
#13 posted 08-27-2019 05:02 PM
Hi, Mike when I first started using a sander I did build a platform for my elsworth jig and it worked great. however i got a one system. i miss the sander. I started using a 40/40 grind so i am doing mostly platform sharpening.
