Delta 14" bandsaw catastrophic failure
Forum topic by pipesmoker posted 08-16-2019 03:29 AM 495 views 0 times favorited 5 replies Add to Favorites Watch
View pipesmoker's profile
pipesmoker
6 posts in 2196 days
08-16-2019 03:29 AM
Topic tags/keywords: bandsaw
I picked up this Delta bandsaw, Model 28-276, curbside. It had broken trunions, which I replaced. My son used the saw a few times without issue. One day he turned it on and both tires broke. The blade did not break. What could have caused this? I don’t want to replace the tires until I know. Thanks.
5 replies so far
View MrUnix's profile
MrUnix
7469 posts in 2681 days
#1 posted 08-16-2019 03:49 AM
Old and dried out original rubber tires?
View bruc101's profile
bruc101
1361 posts in 4023 days
#2 posted 08-16-2019 04:43 AM
- MrUnix
That would be my guess also.
-- Bruce Free Plans https://traditionalwoodworking.org
View CaptainKlutz's profile
CaptainKlutz
1776 posts in 1976 days
#3 posted 08-16-2019 09:38 AM
- MrUnix
+1 Old tires.
Had the same thing happen on 17” saw a couple days ago. Turn it on, blade moved for 1 second, and boom; upper urethane tire shredded into 3 pieces. Have no clue why.
Read on WWW of one possible reason beyond old tires: If the last use(s) caused excess heating and blade tension was tightened, then saw cooled down without tension release; shrinkage during cool down puts more tension on blade/tire. When it was re-started in cool state, the over tensioning was at it’s highest and if the blade doesn’t break; the tires get compressed heavily and can fail with enough squeeze.
In my case the tire had obvious pinch mark where it failed, and I forgot to remove tension; So this logic made sense to me, but no clue if it’s actual reason? YMMV
pipesmoker
#4 posted 08-17-2019 12:13 PM
Thanks everyone. The tires weren’t dried out. CaptainKlutz, you nailed it! My son gave me a sheepish grin when I read your response.
View MrRon's profile
MrRon
5664 posts in 3725 days
#5 posted 08-17-2019 08:56 PM
I was using my band saw to cut aluminum and the upper band broke. I found that sharp aluminum cuttings were embedded in the rubber and cut through the rubber.
