Forum topic by Mike Turner | posted 08-12-2019 11:55 PM | 2449 views | 1 time favorited | 8 replies | ![]() |
I love these calipers from Lee Valley but I sometimes need them to be longer. Anyone have a good idea how to make something like them longer? I make flutes and I bore the long hole for the flute sound chamber.Occasionally one will drift a little and if I know this I can allow more wood to be left there when finish turning it…just maybe not turning the flute as thin. Anyhow any ideas would be appreciated . I have the longer set. -- Mike,North Carolina |
8 replies so far
#1 posted 08-13-2019 07:43 AM |
Hmm, Wood: If wanted metal set, would use the Sorby design (.vs. Veritas design): Draw it up, find a fab shop with cnc laser, and have them cut out a couple sets in 10-11 gauge sheet steel, then rivet the pivot point. Done. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#2 posted 08-13-2019 08:26 AM |
Thanks!!!!
#3 posted 08-13-2019 09:20 AM |
Most calibers sold to woodturners not really that good for measuring a flute wall thickness. Some folks just use old metal clothes hangers bent to desired shapes. https://www.amazon.com/Radnor%C2%AE-Carbon-Steel-Welding-Pound/dp/B000TVFUV4 If go to page 21 there is an example of something I would make using either clothes hanger or welding rod. Difference being would use two pieces of drilled wood one fixed so don’t move and one movable along length of rods. Would like one end of rod with very slight bend and other rod might not have a bend not sure. https://www.ocwoodworkers.com/scripts/plans/upload/Home%20Made%20Tools.pdf -- Bill |
#4 posted 08-13-2019 04:34 PM |
My take on the above. Each rectangle is 1 8.5×11 sheet of paper. -- "PLUMBER'S BUTT! Get over it, everybody has one" |
#5 posted 08-14-2019 07:52 AM |
Both good ideas fellows.I appreciate it. -- Mike,North Carolina |
#6 posted 10-05-2019 01:32 AM |
I measure the bores of shotguns with a tool that I made. Cheap HF dial gauge, ball bearing to use as a bearing surface on the inside of the bore. Just a bit of plate for the base and dial gauge mount, a couple of tubes. |
#7 posted 10-05-2019 02:45 AM |
Ken, exalent idea for a thickness guage. -- If guns cause crime all of mine are defective Randy |
#8 posted 10-05-2019 08:33 AM |
Wow I like that one! Thanks! -- Mike,North Carolina |
Forum | Topics |
Woodworking Skill Share
13541 |
Woodturning
3007 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2074 |
Finishing
6705 |
8187 |
34175 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7611 |
1696 |
Focus on the Workspace
2748 |
1295 |
Woodworking Trade & Swap
5574 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9898 |
