20mm or 3/4" dog holes custom CNC worktop
Forum topic by Jordan123 posted 08-12-2019 02:59 PM 343 views 0 times favorited 5 replies Add to Favorites Watch
View Jordan123's profile
Jordan123
57 posts in 557 days
08-12-2019 02:59 PM
Im having a workbench top custom CNC’d for me at my local shop.
I’m having trouble with two things.
1. Determining what size dog holes I should use. I know festool uses the 20mm but more companies and products can be used with a 3/4” dog hole.
2. What material should I use? I know most people are using MDF for this. But I could use 3/4” ply also
Thanks
5 replies so far
View BubbaIBA's profile
BubbaIBA
435 posts in 2831 days
#1 posted 08-12-2019 05:12 PM
Jordan123,
I’m trying to envision the need for a CNC’d workbench slab, please explain.
Unless there is a Festool appliance you can not live and work without go for the 3/4”.
ken
Jordan123
#2 posted 08-12-2019 05:18 PM
Well I can CNC a 4×8’ sheet of MDF/plywood for $150, rather than the cost of the MFT which is $700 and is much smaller.
See attached image for MFT home workbench
BubbaIBA
#3 posted 08-13-2019 12:40 AM
Thanks Jordan123,
I was trying to envision a hand tool workbench with a MDF top and CNC dog holes, not that there are not some hand tool workbenches with MDF slabs. A table with 200 dog holes is a different story. Sounds like you want to use Festool accessories, if so I would go with the 20mm holes.
ken
View therealSteveN's profile
therealSteveN
3390 posts in 1029 days
#4 posted 08-13-2019 04:54 AM
Thanks
- Jordan123
Kinda answered your own question there. So many more 3/4” items you can use in a dog hole, and the thing is 99% of them are cheaper than the cheapest green variant. Many offering more utility.
I think that really does depend on how much green Kool Aid you’ve drank before purchasing, some folks have green lips.
MDF is fine, it’s biggest faults are cannot get wet, at least if it’s not waterproofed hint, hint. It also really does need to be well supported. Snapping in half is possible if too much weight, and not enough support occur.
Playing with the Sagulator can help figure loads They show Birch, but only Fir in plywood, so you have to fudge a little. But know BB ply is the best in real use. Put in realistic figures, so if you plan on a 3/4” top, 48” x 36” plug that in. It will give you real figures, and it also will say acceptable, or NOT. Cool tool for figuring loads of shelves, worktops, etc etc.
MDF and fir ply are both way at the bottom, so scroll down.
-- Think safe, be safe
View OleGrump's profile
OleGrump
392 posts in 800 days
#5 posted 08-14-2019 12:54 PM
Go with the 3/4 holes. I wanted to add some additional holes to my Workmate 400. the existing holes were 20mm. What a pain in the ass. (Millimeters are for firearms, not he workshop!) Wound up having to bore the new holes with a 13/16 brace bit, which is slightly larger than the damned 20mm, but the B&D dogs worked fine in them.
Point being, unless you already own a 20mm bit, you’re FAR better off with the 3/4 holes.
-- OleGrump
