Using a 45 degree router bit
Forum topic by woodthaticould posted 08-11-2019 08:47 PM 915 views 0 times favorited 15 replies Add to Favorites Watch
View woodthaticould's profile
woodthaticould
79 posts in 3659 days
08-11-2019 08:47 PM
I’m looking forward to working on the hope chest project I recently asked a question about.
https://www.lumberjocks.com/topics/305737
There are several places in the project where I will be using a 45 degree bevel router bit. I will be cutting the bevels on the edges (not ends) of boards about 3 1/2” wide and 24” long. I’m guessing that this will be, for a rank beginner like me, a better method for making accurate bevel cuts than using the table saw.
I am sure that I’m overlooking something regarding this idea.
15 replies so far
View Rich's profile
Rich
7741 posts in 1921 days
#1 posted 08-11-2019 09:27 PM
Just take the material off in multiple passes on the router table.
woodthaticould
#2 posted 08-11-2019 09:50 PM
Sorry, I overlooked the obvious for some crazy reason.
I assume by the way that I should fine tune the bevel cut by changing the height of the router bit until I get the sharp corner I’m looking for.
View Rich's profile
Rich
#3 posted 08-11-2019 10:04 PM
Either way. Adjust the bit height or move the fence back. I usually get the fence set and raise the bit. When you get close, just start creeping up on it.
Also, and you probably already figured this out, do all of your boards at each height. However, when you get close enough to finish it in one pass, you can creep up on the final cut using one board, and then run the rest.
woodthaticould
#4 posted 08-11-2019 11:00 PM
Thanks very much Rich. As I said, I am a beginner in making things out of wood. But I drew a lot of woodwork when I was young and every now and then I designed something.
View jerryminer's profile
jerryminer
962 posts in 2773 days
#5 posted 08-11-2019 11:08 PM
Trying to cut an edge to a sharp point with a router can be challenging because you lose your reference edge when you make the cut all the way to a point.
For a 24” long work piece, I would attach (with double-stick tape , or hot glue, or brads,...) a sacrificial board as a reference edge. Then you can even slightly over-cut your bevel without losing your reference edge. (Very easy to get some snipe at the end of the piece if you rout away all the edge)
View SMP's profile (online now)
SMP
5052 posts in 1237 days
#6 posted 08-11-2019 11:48 PM
I’ve done them on router table and table saw. You already got good advice. But i’ll add to make sure you keep down pressure on the boards. I’m guessing you don’t have a feeder. Don’t assume boards are flat.
View FirehouseWoodworking's profile
792 posts in 4604 days
#7 posted 08-12-2019 12:32 AM
If you have the ability to do so, here’s a trick to avoid losing the reference edge on your boards.
If possible, start with boards that are WIDER than your finished measurement. Then take one edge down to your desired 45 degrees. As has already been pointed out, take multiple, light passes (either by raising the bit or moving the fence) and holding the board tight to the table.
Once you have the desired “knife edge” at the 45, then set your fence to the final width (plus a little, but not too much) and cut the boards to width on your table saw. Then plane that cut edge down to the exact final width on your jointer or with a hand plane if you don’t have a jointer.
Cheers!
-- Dave; Lansing, Kansas
View Lazyman's profile
Lazyman
8763 posts in 2719 days
#8 posted 08-12-2019 01:06 AM
Already some good info above. Since you say that you are a beginner, I’ll mention that you need to make sure that you move the router in the correct direction.
woodthaticould
#9 posted 08-12-2019 01:49 AM
Thanks everybody. With all this good advice I might actually do this right.
View fly2low's profile
fly2low
88 posts in 1428 days
#10 posted 08-12-2019 03:07 AM
I was recently doing some raised panels on the router table, and was having a very difficult time getting a smooth consistent cut. I was conscious of keeping downward pressure, but was obviously not consistent.
Got a set of these – problem solved
https://jessem.com/collections/router-table-accessories/products/clear-cut-stock-guides
-- Rich Gig Harbor, WA
woodthaticould
#11 posted 08-12-2019 03:24 AM
I saw them in an online tutorial and wrote them on my to buy list. Are they as good a product as they appear?
fly2low
#12 posted 08-12-2019 04:35 AM
They solved my problem
I am happy wth them. Have the set for the TS as well. No affiliation, just a happy customer
jerryminer
#13 posted 08-12-2019 03:12 PM
- woodthaticould
I have them and love them. Not quite a power feeder, but a close second
View pottz's profile
pottz
22256 posts in 2316 days
#14 posted 08-12-2019 03:16 PM
- woodthaticould
- jerryminer
ill second that they work great and very well made.
woodthaticould
#15 posted 08-13-2019 05:17 PM
Thanks everybody.
The 45 degree router bit hasn’t arrived yet but I just received the Yonico bits that I ordered for all the tongue and groove joints on this project. Nice packaging by the way, a finger jointed box.
They are, for a new guy like me, pretty scary looking. I think I’ll be ordering the Jessem guides now instead of later.
