How to fasten temporarily
« back to Joinery forum
Forum topic by woodthaticould posted 08-06-2019 09:51 PM 951 views 0 times favorited 32 replies Add to Favorites Watch
View woodthaticould's profile
woodthaticould
79 posts in 3547 days
08-06-2019 09:51 PM
Greetings, everybody:
I’m working on a project (a hope chest) and want to fasten it together temporarily so we can live with it for awhile. I’m not sure about certain details, one of which being which veneer I want for the recessed panels. The joinery for the rails, stiles, and panels will be mostly tongue and groove and the case will go together with dowels. I was thinking about adding blue tape to tongues and dowels to tighten the joints hold until I’m ready to glue up. I’m sure there’s a better way to do this and so I’m throwing it out to all you experts.
32 replies so far
View Rich's profile
Rich
7393 posts in 1809 days
#1 posted 08-06-2019 10:08 PM
I would be concerned about residue from tape. Perhaps a ratcheting tie-down strap would work, or if you have a strap clamp, like the Bessey, that will work well.
View johnstoneb's profile
johnstoneb
3175 posts in 3392 days
#2 posted 08-06-2019 10:25 PM
Just remember this: There is nothing more permanent than a temporary fix.
-- Bruce, Boise, ID
View BurlyBob's profile
BurlyBob
9308 posts in 3485 days
#3 posted 08-06-2019 10:56 PM
That’s a good one Bruce. I’m going to remember it for sure.
View bilyo's profile
bilyo
1398 posts in 2322 days
#4 posted 08-06-2019 10:58 PM
What you do, I think, depends a lot on how you ultimately intend to assemble it and, to some extent, the type of wood you are using. The first thing that comes to my mind is to use small dabs of hide glue in locations where it will be easy to sand/scrape it off later. Do not put it on mortise and tenons or dowels. Treat it like it is all butt joint assembly. Disassembly would be relatively easy with heat and moisture. Hot melt glue also comes to mind but, I’m not sure how residue might affect finial finishing. If there are any places that will be hidden or out of sight after final assembly, you might use a few pocket screws. The pockets could be filled later if needed.
View SMP's profile
SMP
4750 posts in 1125 days
#5 posted 08-06-2019 11:32 PM
- johnstoneb
Yep, will be telling the grandkids about the vintage tie straps that you used on it from “back in the day” that you purchased at an actual brick and mortar store using a plastic card that functioned as dollar based currency.
View ibewjon's profile
ibewjon
2610 posts in 4012 days
#6 posted 08-06-2019 11:53 PM
I think I would use the straps with corner protection. No residue to worry about
bilyo
#7 posted 08-07-2019 12:52 AM
- ibewjon
I could be mistaken but, my impression was that the OP wants it to look as complete as possible while being temporarily connected. Would exposed straps be consistent with that?
woodthaticould
#8 posted 08-07-2019 12:35 PM
Thanks all. I won’t respond to every comment but I appreciate them all. And yes, although I neglected to say it, I wanted the project to look completed except for finishing while being able to disassemble and finish without too much difficulty.
View Robert's profile
Robert
4716 posts in 2700 days
#9 posted 08-07-2019 01:05 PM
Knock down hardware?
View JohnMcClure's profile
JohnMcClure
1371 posts in 1860 days
#10 posted 08-07-2019 01:08 PM
If the joints are mallet-tight it may hold together without glue for a couple weeks. If they aren’t mallet tight you could shim them with paper to tighten them up. But that totally depends on the construction.
Agreeing with Bruce, a lot of “temporary” items end up being permanent. We still use a craft table that is barely more than some 1/2” plywood on 1×2 legs with butt-joined 1×2 stretchers. I never expected it to last, but it’s been 10 years.
-- I'd rather be a hammer than a nail
View Woodtodust's profile
Woodtodust
85 posts in 3056 days
#11 posted 08-07-2019 01:30 PM
How about pocket screws? They’ll be on the inside, can easily be removed and will hold it together until you decide to glue it up. Just eight would do it. Then fill the holes when you’re done.
-- Bill...Richmond Hill, GA--"83% of all statistics are made up."
bilyo
#12 posted 08-07-2019 02:06 PM
How about a few of these at inside corners. Small screws or even nails would leave only small out of sight holes to fill.
View Lazyman's profile
Lazyman
7834 posts in 2607 days
#13 posted 08-07-2019 02:10 PM
If you can put tape in with the dowels or the rails and stiles, they are too loose, IMO. You might be able to get a thin piece of paper in the rail and stile joints but not in the dowel holes.
Why exactly do you want to do this? It isn’t necessary for dry assembly.
woodthaticould
#14 posted 08-07-2019 02:44 PM
Apparently I am a very confused person. I will work on that and then work some wood.
View hairy's profile
hairy
3305 posts in 4751 days
#15 posted 08-07-2019 03:42 PM
Tape residue is easily removed with mineral spirits. I normally rub down projects with mineral spirits before applying finish, it cleans up the dust, exposes scratches and glue that I missed and won’t hurt a finish.
Double sided tape might work in some places if you just use a little, too much will give you headaches when trying to disassemble.
-- there's someone in my head but it's not me...
showing 1 through 15 of 32 replies
