Forum topic by lazrus55 | posted 08-01-2019 01:14 PM | 875 views | 0 times favorited | 18 replies | ![]() |
Topic tags/keywords: question So I agreed to build a mantel and when I completed the build it looked amazing. I delivered it and the guy started staining it. He sent me this picture and asked what I did to the top. I have no idea. Can anyone point out my mistake? |
18 replies so far
#1 posted 08-01-2019 01:26 PM |
Could just be the wood. How did you prep it? -- Everything is a prototype thats why its one of a kind!! |
#2 posted 08-01-2019 01:39 PM |
so – you made the mantle and delivered it unfinished ? magnifying the photo and looking closely at the issue, . -- there is no educational alternative to having a front row seat in the School of Hard Knocks. -- |
#3 posted 08-01-2019 01:43 PM |
It is a little hard to tell from the photo. Either, or, 2) You got some bleed out of the stain after the sealer coat was applied. Bleed out is pretty common with open grained woods like Oak, or Ash. Excess uncured stain gets trapped in the pores and gets drawn back to the surface when the sealer coat dries. Good luck. BTW, I don’t consider a wavy figure to be a defect – just the character of certain woods. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#4 posted 08-01-2019 01:56 PM |
Why are you asking what you did wrong? Customer accepted the unfinished piece, he definitely owns it now. If you want to help him, and us to help, we need the complete finish schedule and the branded products used. More than likely this will need to be stripped off and start again. |
#5 posted 08-01-2019 02:16 PM |
Tell him it’s curly red oak |
#6 posted 08-01-2019 02:28 PM |
\ Birds eye red oak |
#7 posted 08-01-2019 02:39 PM |
Looks like it got splashed with water or something. Like a spray when you open a carbonated drink. |
#8 posted 08-01-2019 02:47 PM |
Is it possible that some rain or water hit this prior to staining? I have seen floor sanders freakout when on a rainy day someone gets water on an unfinished floor. I think it is also incumbent to sand and clean any unfinished wood that could have picked up any rain, sprinker, dew and fingerprint oils etc. prior to staining. There is also a pre stain conditioner that can help even out the rate of absorption but this is normally used on soft pine. |
#9 posted 08-01-2019 02:52 PM |
Talk about cojones. This guy has the nerve to ask what you did to it? When someone decides to do their own finishing, they are responsible for the result. The only mistake you could make is to offer to fix it for free. I let one client do their own finishing on a cherry bathroom vanity. When I saw it, it was pure blotch. They loved it though and had no idea how bad of a job they did. Of course, I lied and said it was awesome. But, if they’d called me and asked what I did to make it blotch, I would have explained to them where they went wrong. This highlights the need to put things in writing. When I get sign-off on a project, I’ve outlined, in detail, every thing the project will include and what I’ll be delivering. I go over each item with them to make sure they understand, and then we both sign it. Without that, you’re putting yourself at risk. You needed to spell out in detail what you were delivering and part of that would be how you will do final prep on the board (what grit, etc) and that once the customer accepts the piece, it’s their responsibility. You’ve delivered what you both agreed to and signed off on it. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#10 posted 08-01-2019 03:15 PM |
did customer use steel wool in his finishing process? Steel wool can cause dark spots in oak if some wool fibers are left. -- Putty |
#11 posted 08-01-2019 06:32 PM |
Look at the direction of all the little marks? |
#12 posted 08-01-2019 06:44 PM |
Out of curiosity, what was your final sanding grit.. you don’t know how he handled the peice, or any sweat dripped off onto the piece, Did your client clean or wipe clean before staining and did he do light sanding between coats. This is one of the reasons I have this on the bottom of my Estimate Wish List sheet and also on the bottom of my Invoices.. |
#13 posted 08-01-2019 07:17 PM |
I don’t understand. Is the customer complaining about the roughly parallel shadowy areas on the left half of the panel, the various random dark spots or the mysterious red marks all over the panel? If it’s the shadowy darker areas, that looks to me like some very faint curl in the grain that absorbed more stain than the rest of the board. It’s a natural phenomenon. It could have been reduced or eliminated by applying a thin wash coat of shellac before applying the stain. Probably nothing to be done at this point short of stripping the whole thing and starting over. Even then, you might not get the stain completely out of the curly grain. I have no idea what the dark spots or the little red lines are, but they look like the result of sloppy finishing technique. |
#14 posted 08-01-2019 07:33 PM |
MP, the red lines aren’t on the wood, |
#15 posted 08-01-2019 07:44 PM |
LeeRoy nailed it. Something got sprayed on it. Depending on who he is, I’d tell him to take a hike. -- Everything is a prototype thats why its one of a kind!! |
Forum | Topics |
Woodworking Skill Share
13129 |
Woodturning
2775 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1862 |
Finishing
6293 |
7844 |
32501 |
CNC Woodworking
324 |
Hand Tools
6418 |
Jigs & Fixtures
1781 |
Wood & Lumber
7236 |
1612 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5389 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9620 |
