Designer asked for a stain to be done at 50%, what did I just agree too?
Forum topic by PaulLL posted 07-31-2019 06:46 AM 1812 views 0 times favorited 15 replies Add to Favorites Watch
View PaulLL's profile
PaulLL
163 posts in 3268 days
07-31-2019 06:46 AM
Topic tags/keywords: finish stain 50 application oak plywood finishing staining designer table console
Hi everyone! Been a long time, I’ve gotten way more into metalwork so I’ve dropped the ball on being a contributing member! I’m hoping someone can still help me out though?! Please?
So I’m builidng a steel console table, it’s going to have a oak plywood top inserted into angle iron. I showed the designer a couple sample boards I made with some stains I have. Whe chose dark walnut, but said “can you do this at 50%?” Of course I said yes! I’m thinking that just means to cut the stain with a thinner 1:1, but I was hoping someone could confirm that. Thank you in advance!
Paul
15 replies so far
View John Smith's profile
John Smith
3022 posts in 1454 days
#1 posted 07-31-2019 11:34 AM
what kind of stain are you using ?
it may not be as simple as just adding more thinner to achieve
a lighter tone without “mudding it up”.
-- I am a painter: that's what I do, I like to paint things. --
View GrantA's profile
GrantA
3164 posts in 2699 days
#2 posted 07-31-2019 12:24 PM
Since it’s oak ply (not expensive) and assuming they can take a joke I’d stain half the board and give it to them :-D
You said designer, so there’s no telling what they mean.
It’s always better to say something like “sorry I’m not familiar with that but I’m sure I can do it if I know exactly what you’re asking for” up front, now you have to go back and say something like “just to be sure did you mean you wanted the stain half as dark as before?”
7302 posts in 3785 days
#3 posted 07-31-2019 12:38 PM
You will need to try it out to create a sample board (be sure to get approval), so that will give you your answer. For the record I don’t think thinning it out (by itself) will do what you want.
View RobHannon's profile
RobHannon
347 posts in 1822 days
#4 posted 07-31-2019 12:56 PM
Fred and John are right, thinning it may just make a different color. Not necessarily a pleasant one. Make some sample chips out of the cut-offs from the top and try some different techniques to lighten it. Closing the wood pores with a prefinish or sealer may slow absorption and give you a lighter shade in the same color family.
View GR8HUNTER's profile
GR8HUNTER
9152 posts in 2004 days
#5 posted 07-31-2019 01:33 PM
You will need to try it out to create a sample board (be sure to get approval), so that will give you your answer. For the record I don t think thinning it out (by itself) will do what you want.
- Fred Hargis
DITTO ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ :<))))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
View SMP's profile
SMP
4988 posts in 1197 days
#6 posted 07-31-2019 01:53 PM
Give them a sample that has 2 coats on one half, and 1 coat on the other half, and explain that 1 coat is 50%.
View bilyo's profile
bilyo
1423 posts in 2394 days
#7 posted 07-31-2019 02:18 PM
50% of previously agreed to cost ??? I hope not !
PaulLL
#8 posted 07-31-2019 02:25 PM
John, I’m using minwax wood finish, dark walnut#2716
Rob, I didn’t use a sealer on my original sample, I’ll definitely give that a try
Thanks guys
View Lazyman's profile
Lazyman
8342 posts in 2679 days
#9 posted 07-31-2019 02:59 PM
Watco has 3 shades of walnut finish (light, medium and dark). If the thinning doesn’t work out I would give them a test board with each shade of the Watco on it and let them choose which one they want. Another option would be to mix your own using General finishes stains. They actually have a display in my local Woodcraft that demonstrates some of the possibilities for mixing your own custom colors. I have also adjusted some with Transtint dyes as well where I added a little walnut brown to tone down a reddish hue.
View SMP's profile
SMP
#10 posted 07-31-2019 03:40 PM
Thanks guys
- PaulLL
If you do the Charles Neil white glue and water sealer, that will lighten it quite a bit.
PaulLL
#11 posted 07-31-2019 03:49 PM
Thanks Nathan I’ll look into that!
View CaptainKlutz's profile
CaptainKlutz
5033 posts in 2786 days
#12 posted 07-31-2019 04:01 PM
+1 Make some practice runs, Give sample, Get approval first. Don’t forget to add 25% to cost to cover the custom color work. LOL
+1 Thinning stains may not be the right answer! May need a different color stain!
Thinning oil based pigmented stains doesn’t reduce the color, it only changes how much you apply each time. With dark stains that contain black pigments, you don’t make really them lighter, you get a ‘washed out’ look, with black and random red/yellow/brown shades.
Thinning a dye stain is completely different matter. Sometimes you get same color only lighter, other times you get a weird shifted color due red/yellow/black levels.
Testing is only way to know.
PS – If the designer customer wants a custom color, get a sample and take it your local industrial wood finish supplier. All my Mohawk & Sherwin Williams distributors in town can custom blend colors on demand.
Best Luck!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View DS's profile
DS
3996 posts in 3712 days
#13 posted 08-03-2019 08:14 PM
This usually means 50 percent less dark, however that is achieved.
However, these are really subjective terms, even if it sounds numerically specific. Only the designer can tell you what she meant by it.
You have to ask these questions and still make a sample and get signatures approving it.
I once had a designer that insisted on using Macassar Ebony, but she asked could I tone down the yellow/orange stripes.
I said no, they would take away my wood worker card if I did that. She went with Gunmetal Ebony – it suited her perfectly.
-- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS
View Andybb's profile
Andybb
3346 posts in 1895 days
#14 posted 08-03-2019 09:38 PM
Just ask. “What do you mean by 50%?” Are they trying to match something? Do they have a sample of what they want?
-- Andy - Seattle USA
View Kazooman's profile
Kazooman
1540 posts in 3244 days
#15 posted 08-03-2019 10:21 PM
I didn’t see it mentioned in the replies and it probably goes without saying, but I will say it anyway. You should apply at least one coat of the final finish to the samples before you show them to the client. The finish coat can really change the appearance of the piece.
