Remove impressions in wipe on polyurethane finish
Forum topic by nek4life posted 07-27-2019 01:48 PM 1077 views 0 times favorited 15 replies Add to Favorites Watch
View nek4life's profile
nek4life
29 posts in 726 days
07-27-2019 01:48 PM
Topic tags/keywords: question maple finishing shaker
I’m using a wipe on poly finish for the first time (General Finishes Arm-R-Seal) and ended up getting some impressions left in the poly where the I had bench cookie finishing cones placed underneath. I had let the finish dry 24 hours, but didn’t realize it was still soft and when I sanded the bottom of the table top I must have been pressing too hard and left a few marks in the top.
Do I just need to sand the finish on the top back down to the same level as the impressions or is there a way to fill them then sand it out from the top? This is my first real project and I would like to have a pristine finish at the very least on the table top.
I can try to get some pictures later if necessary, but I’m hoping my description here is enough. The impressions are maybe 2mm ish deep, but very visible from the top and especially in the sheen.
Thanks!
15 replies so far
6834 posts in 3503 days
#1 posted 07-27-2019 03:43 PM
I’m on the side of you need to remove what’s there and start over. Trying to repair this kind of problem is possible, but there are limits to what can be done and how well it turns out. Given this is your first “real” project, removing it and starting with fresh coats would be best (IMHO). You didn’t mention how many coats you applied, but it may be a thin film build to remove. Also, sanding is possible, but the finish needs to be fairly well cured. If you see “corns” on the sandpaper, it isn’t dry enough. Scraping it off…or using a chemical remover (stripper) might be a better choice.
View Gene Howe's profile
Gene Howe
12302 posts in 4438 days
#2 posted 07-27-2019 04:10 PM
The container likely has this info. But just in case…Dry Timeshttps://generalfinishes.com/wood-finishes-retail/oil-based-topcoats/arm-r-seal-oil-based-topcoat
Looks like you can sand after 72 hours…depending on humidity.
As Fred indicated, sanding is the best way to go.
View SMP's profile
SMP
3436 posts in 915 days
#3 posted 07-27-2019 04:28 PM
I’ve made that mistake before. That is why now I always finish the “show side” last. And if the other side gets some marks and isn’t going to be visible, i just leave it. But you got advice for how to fix it this time. Good luck!
View CharlesNeil's profile
CharlesNeil
2501 posts in 4880 days
#4 posted 07-27-2019 04:32 PM
you have 2 issues
uncured finish
bench cookies have a plastic/rubber coating
most all finishes are a form of plastic , and will react with most any finish
I have seen those plastic place mats , eat into and be impossible to remove even on well cure finishes
NEVER , put any plastic in contact with a finish for any period of time .
Bubble wrap is a disaster waiting to happen , on a relatively new finish can really do a number
always put cloth or paper in between
I agree sand it down and start over
View LeeRoyMan's profile
LeeRoyMan
1538 posts in 736 days
#5 posted 07-27-2019 05:30 PM
you have 2 issues
uncured finish
- CharlesNeil
Is this really you?
I read on another forum that you had died. Glad you’re alive.
CharlesNeil
#6 posted 07-27-2019 05:34 PM
Sorry to disappoint
I’m doing well
CharlesNeil
#7 posted 07-27-2019 05:38 PM
Sorry to disappoint
I’m doing well
Kinda backed off the internet
Rather be fishing.
LeeRoyMan
#8 posted 07-27-2019 05:39 PM
No disappointment here,
I always figured you would live to be 110 – 115
(Keep fishing and you might make it that long.)
nek4life
#9 posted 07-27-2019 11:23 PM
I have 2 coats of Seal-A-Cell and 2 coats of Arm-R-Seal currently applied. My plan was to put one more coat of Arm-R-Seal and call it a day. Based on the feedback here I think what I’ll do is finish up the table legs and aprons and then the bottom side of the table top. Then I’ll let the top finish drying for the a few more days then sand it back until the marks are gone then reapply the Arm-R-Seal to the table top only.
The only reason I say this is my first “real” project is because I took a community workshop at Vermont Woodworking School and milled all the sugar maple from rough lumber and made a nice shaker style table. It’s only the second piece of furniture I’ve made. The instructor did a lot of the setup, but I’m actually really impressed that I was actually able to make something so nice so I don’t want to screw it up!
Thanks for all the help. I love this forum. So many people have such great info to share here!
View therealSteveN's profile
therealSteveN
7238 posts in 1583 days
#10 posted 07-28-2019 02:38 AM
Sand to where you were when you started application, then go 2 grits further. So if you were at 220, go 300, and 360. Tack off any dust, and nibs.
This is General Finishes application info.. On this page scroll down, and look for the 6 steps. Read the first 2 completely.
What Charles told you about plastic is very true. The best prop I have found to keep an in progress finish piece off the table is buy some heavy duty roofing nails (longer than regular ones). Cut a bunch of 4” squares of something 3/4” thick, and drill a hole the size of the nail through the middle of each piece of wood. Insert a nail, and presto, you have a secure, stable prop to hold parts up while the finish dries. No chemical mayhem, and Cheeeeep.
-- Think safe, be safe
CharlesNeil
#11 posted 07-28-2019 12:38 PM
nek for life
not a gpod idea, oil is a liquid, and it can swell the wood , you really need to do both sides at the same time or it can cup the top
View Rich's profile (online now)
Rich
6535 posts in 1599 days
#12 posted 07-29-2019 04:29 AM
To support boards I’m finishing, I use the tack strips they sell for carpet installation. They are four foot long strips of one inch wide wood with dozens of sharp tacks protruding from the surface. You can buy a box of 100 strips (a lifetime supply) for about $20. They come with nails ready to drive for the carpet installer that you can remove with pliers. They work well for supporting boards being finished, because they spread the weight so evenly over them and don’t leave a pronounced mark in the side that is resting on them.
Like SMP, I like to finish the show side last. Even if the tack strips leave a mark, who cares? It’s on the bottom.
I use them in multiple ways. I have 2 foot square pieces of 1/4” MDF with the strips glued and pin nailed at 4 inch intervals. I also have a couple with a solid bed of tack strips. Finally, a few dozen pieces of 3” by 5” MDF with strips that I can spread around on my spray table for various setups.
nek4life
#13 posted 07-31-2019 10:51 AM
So I got stripped all the poly off of the table top and realized I had actually dented the wood so there was a bit of sanding I needed to do in order to remove them. I tried raising the dents with warm water, but they didn’t move much, but a bit of sanding removed them.
I haven’t started refinishing yet, but this time around I’m going to be more careful to not put any pressure on the table top while sanding especially not while on the finishing cones.
I might look into some of the other suggestions above to have the piece rest on instead of the finishing cones I currently have now and will also let the poly dry longer in between.
Thanks!
View MPython's profile
MPython
338 posts in 822 days
#14 posted 07-31-2019 12:49 PM
I tried raising the dents with warm water, but they didn t move much, but a bit of sanding removed them.
Thanks!
- nek4life
Get a piece of clean cloth and dip it in water, preferably distilled water to make sure you don’t end up with mineral stains on your nice table top. The cloth should be pretty damp, but not dripping wet. Place the wet cloth on the dent and touch it with the tip of a hot clothes iron. The steam created will penetrate the wood fibers much better than warm water and raise the dent. Sometimes it takes a couple of applications, depending on how deep the dent is and whether the fibers are badly damaged.
View avsmusic1's profile
avsmusic1
680 posts in 1694 days
#15 posted 07-31-2019 09:28 PM
if you’re pressing so hard you dented the wood you probably need to let up and change paper more frequently
