07-26-2019 01:27 AM
Topic tags/keywords:
live edge
knots
tearout
I’m new to Lumberjocks.
I’m just getting started on a live edge, i.e. Nakashima style, coffee table for my daughter. It’s my first live edge project. I’m sure I’ll have a number of questions as I go along. But the first one has to do with dealing with the knots, especially the sapwood-colored one you can see in the first picture. Really gnarly grain on it. Of course I know that in the area around knots grain is always problematic. But I set up my bevel up plane with a 50 degree blade (62 degree total included angle with the bed) with which I’ve been able to plane birds eye maple without tearout, and it was no good. Then I even tried a properly prepared scraper, and even that gave tearout! So, what’s the right strategy for this particularly knotty knot? Should I resort to only sanding that area? Should I fill it with say cyanoacrylate glue and then plane or sand? There are other knots with dark wood that don’t tear nearly to the extent this does. Some of the dark nots are partly cracked around the knot. I’m assuming I should fill those cracks with 2 part epoxy?
There are some larger cracks that I’ll be stabilizing with butterflies. But small ones (some of which terminate out at the edge) that I plan to fill with epoxy (or pehap CAG if they’re really hairline?). Any mistakes in this plan, or just general advice?
Moisture meter is on order to check that the wood is ok before proceeding much farther. I got the kiln dried slab from an established Eastern PA sawmill with a good reputation.
-- Fritz from Pennsylvania
#1 posted 07-26-2019 02:48 AM
When sharp tools don’t work to calm multidirectional grain. I sand a bit, then go back to the card scraper. If it feels rough, and is as swirled as that second pic shows, that would be my plan.
As for that knot, it is a high impact visual interest. I would clean it up, and use it to it’s best advantage. You have 2 of them, in that bed of swirled grain. I see an Owl, and I don’t do visions. It would be a shame to take the Owl away. If you add the entire swath of heartwood going away from that it becomes a Loon. Leave the eyes at all cost. Mother Nature took a few years to get them right.
-- Think safe, be safe
#2 posted 08-07-2019 11:56 AM
On highly figured wood, I use helical cutterheads and sanders. Seems every hand tool, no matter how sharp, will mess up your project, because the grain changes directions. A big belt sander will smooth up that piece. Usually I try to glue knots back to the piece, and they will usually blow out about the time I get the piece to thickness, so then I either carve a piece to fit in the hole, or use bondo to fill it in, and then color the bondo with a marker usually black or dark brown, as many knots are those colors.
#3 posted 08-07-2019 01:41 PM
Seems every hand tool, no matter how sharp, will mess up your project, because the grain changes directions. - farmfromkansas
This is often true.
The problem with tear out is you don’t know until its too late.
#4 posted 08-07-2019 02:03 PM
I’ve had some quilted maple that gave me the same problems, even a freshly sharpened card scraper would cause tear out. I resorted to sanding as the only method that wouldn’t cause tear out of some sort.
-- Bondo Gaposis
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13543 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
3009 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
618 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
436 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
2076 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6709 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
8187 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
34179 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
384 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6768 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1920 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7615 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1696 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2749 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1295 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5576 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2431 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9900 |
