stock thickness when cutting thru dovetails...Incra LS
Forum topic by Florida Gramps posted 07-23-2019 04:13 PM 154 views 0 times favorited 2 replies Add to Favorites Watch
View Florida Gramps's profile
Florida Gramps
18 posts in 1478 days
07-23-2019 04:13 PM
I have been told that stock thickness is critical when making thru dovetails using Incra LS. I do not have a thickness planer. I am thinking that after i play with adjusting cutter until I have a nice dovetail fit, I should make a template and save for future height adjustments with that cutter…....and then take my template to a mill and have stocked planed to a precise thickness…...appreciate comments from an experienced LS user….I have had mine for 2 days and am still setting it up
-- Florida Gramps
2 replies so far
View Gene Howe's profile
Gene Howe
11702 posts in 3880 days
#1 posted 07-23-2019 04:36 PM
As long as all mating pieces are the same thickness, you’re good. But having them planed to exact thickness is better.
View dbw's profile
dbw
298 posts in 2088 days
#2 posted 07-23-2019 05:18 PM
As long as all mating pieces are the same thickness, you re good. But having them planed to exact thickness is better.
- Gene Howe
Yup
-- measure 3 times, cut once
