Sorby question
« back to Woodturning forum
Forum topic by Karda posted 07-22-2019 07:56 PM 335 views 0 times favorited 16 replies Add to Favorites Watch
View Karda's profile
Karda
1611 posts in 1001 days
07-22-2019 07:56 PM
I have a Sorby 3/8ths bowl gouge I want to rehandle. Does any body know what size hole I would need. The gouge is the same as an American 1/2 inch thanks
16 replies so far
View LeeMills's profile
LeeMills
675 posts in 1748 days
#1 posted 07-22-2019 09:57 PM
Should be a 1/2” hole. I would drill a hole in a piece of scrap to check before drilling the handle.
Karda
#2 posted 07-22-2019 10:22 PM
does it step down at the tang, my 5/8th gouges have a 1/2 inch tang. I don’t want to take off the handle till I have the right hole drilled, at least if I don’t have to thanks Mike
View Nubsnstubs's profile
Nubsnstubs
1588 posts in 2177 days
#3 posted 07-23-2019 01:15 PM
- LeeMills
Lee, would you like to explain why Mike would need a 1/2” hole for a 3/8’ shaft…...
Mike, if your shaft is 3/8”, you should drill a 3/8” hole about 2” deep. Apply a little epoxy of some sort inside the hole at the top, and push or use a clamp to bottom out the shaft into the hole. ............... Jerry (in Tucson)
View Lazyman's profile
Lazyman
3661 posts in 1835 days
#4 posted 07-23-2019 01:43 PM
Most bowl gouges are milled from a straight rod so the width where it enters the current handle should be the same all the way to the end. You may want to remove it from the handle before you completely finish drilling the hole just so you know how deep the hole is, assuming you want to set it at the same depth.
If I remember correctly, the English made gouge measurements are given as the width of the flute, not the width of the shaft so they would use a 1/2” to make a 3/8” gouge. Measure carefully to make sure that it is not a metric size. If is is actually 12mm for example, a 1/2 hole might be a little too big.
LeeMills
#5 posted 07-23-2019 01:56 PM
Lee, would you like to explain why Mike would need a 1/2” hole for a 3/8 shaft…...
- Nubsnstubs
As Lazyman explained, UK made bowl gouges (not spindle gouges) are sized differently from the rest of the world.
Size of the bar is 1/8” larger than the stated gouge size. A 3/8 Sorby would be 1/2 bar; a 1/2 Sorby would be 5/8 bar.
Nubsnstubs
#6 posted 07-23-2019 02:06 PM
- Nubsnstubs
- LeeMills
Thanks, Lee, I was just keeping you on your toes.
Anyway Mike, all my gouges and other turning chisels I have are embedded about 2” deep. That’s your depth you probably need…........ Jerry (in Tucson)
Karda
#7 posted 07-23-2019 03:50 PM
thanks , I got the size difference. My concern is the tang, My P&N is stepped down to 1/2 inch and so is my BB. I don’t want to happen with my sorby. If i drill the wrong size hole the blank is toast. I did drill a 1/2 inch hole in a cut of from the blank. The hole is a hair to small. How can I get the handle off with out cutting it off
View TheDane's profile
TheDane
5665 posts in 4110 days
#8 posted 07-24-2019 12:52 AM
Clamp the steel in a vise and use a block of wood to whack it with a mallet. I don’t know about Sorby, but many tool manufacturers don’t use glue or epoxy … the tool steel is just pressed into the hole in the handle.
Karda
#9 posted 07-24-2019 03:02 AM
all I have is a work mate, I’ll try that
View OSU55's profile
OSU55
2380 posts in 2437 days
#10 posted 07-24-2019 12:16 PM
Applying a little heat with a torch can help handle removal, glue or not.
Karda
#11 posted 07-24-2019 02:51 PM
never thought of heat, couldn’t drive it off so I cut it off. tang is larger than shaft. The flute is a fractin of a millimeter smaller than the tang. My .5” drill is 12.6MM the tanh is 13MM
View Mosquito's profile
Mosquito
9804 posts in 2739 days
#12 posted 07-24-2019 04:39 PM
Do you happen to have pictures by chance? I’ve thought about re-handling my Sorby bowl gouges as well, so I’m curious.
So the shaft is about 1/2” in diameter, and the tang is 13mm? That’s an interesting approach by Sorby, I would have thought they’d just do 1/2” rod for the whole thing, or 13mm for the whole thing. Seems expensive to take a 13mm bar and turn it down to 1/2”...
And was the 13mm tang the whole section inside the handle (including the ferrule)?
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
Karda
#13 posted 07-24-2019 10:27 PM
Hi, this time I zeroed my calipers. The full length of the shaft is 13MM. So my drill is less than a MM smaller than shaft. i can live with that. But if you has a 13 MM drill bit that would make the job easier.
TheDane
#14 posted 07-25-2019 12:30 AM
Length? Do you mean diameter?
If the shaft is 13mm, you need a 13mm drill.
Mosquito
#15 posted 07-25-2019 12:48 AM
he means over the entire length, it’s 13mm in diameter
Thanks for the follow up Karda
