Is there an advantage to using 8/4 over 12/4 lumber for a laminated workbench?
I plan on building a European workbench with a 3" thick top. I will be ripping 3" strips and rotating them 90 degrees and gluing the face grain together. I have read several articles and most makers are choosing 8/4 boards. It seems it would be less work if every strip was closer to 3" wide than only about 2" wide. The only reason I could foresee using 8/4 is your saw would not cut through 12/4 on one pass, although I'd be more I nclined to make the cut in 2 passes over choosing thinner lumber.
I've not worked with 12/4, so I am asking what seems to me to be a ridiculous question - Is there a disadvantage of choosing 12/4 over 8/4?
If you're rotating and gluing face grain, then 8/4 will work fine. Just cut 3" wide strips from it, then rotate it 90º and resaw pieces for the top. With 12/4 you can slice the pieces straight from the plank. You'll wind up with pretty much the same result. You'll be dealing with ripping pieces from 3" stock whether you use 8/4 turned sideways or 12/4 straight up.
What you need is a band saw. Even a small model will cut 3" stock.
As stated you are looking at the same yield. I would think 8/4 should be less $$$$$ But you are buying. Are you actually in the Nati? If you can buy 8/4, and 12/4 same price kindly send me a PM where that is.
As stated price usually, but if you are using 12/4 with say an 8" width, which is pretty normal for 12/4, and you are at 6' long, and it's Maple, those weigh a bunch. Lifting, and cutting 8/4 also 8" x 6' is a breeze comparatively.
I also would suggest bandsaw to slice these, rather than a TS and especially if you need to do a 2 cut. So much wasted stock, versus the tiny kerf from a bandsaw. BUT again I'll point out weight, with the 8/4 you could likely do the cuts without a lot of fanfare, and supports. The 12/4 would need support.
One more thing, I think it'll be important to run the strips you cut through a planer on both sides. It doesn't matter whether they're straight, but it does matter that their faces are parallel.
Another advantage to using 8/4 and doing a 'rip and flip' is that you'll more than likely be using flat sawn 8/4(more widely available). When you turn the pieces on edge, you'll now have quarter sawn lumber.
Much more stable than a flat sawn table top.
This was mentioned above, but 8/4 is cheaper, and to be honest I can't even buy 12/4 at my sawmills…..I think that's why you see 8/4 mentioned so often.
Suggest if you want a laminated table top panel that is 3" thick when complete; start with ripped planks wider than 3 inches. My personal rule of thumb:
For small panels < 24" long, +1/8" extra width
For medium 4-5ft long panels, +1/4"
For large 6-8ft long panels, +3/8"
Can easily lose the above extra thickness making panels flat after glue up.
Will lose 150% of the above amounts if you allow warped/twisted boards into the laminated stack. DAMHIK
Also don't forget that with a wood hand tool bench, it will get resurfaced and flattened every couple years of hard use. For light home use, resurfaced maybe once every 5 years? This removes additional thickness each time.
So if want a minimum 3" thick bench top in 10-20 years, suggest you start with 3.75" wide boards today. lol
+1 Use 8/4 lumber.
While 12/4 lumber will work, you have to make sure the beams are still flat sawn thru entire thickness, and not from center of tree. Goal is to make a quarter sawn laminated panel. If you put center grain or pith into the lamination, you will see additional seasonal movement due moisture changes.
Cheers!
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
