Rubio Monocoat vs Osmo Wood Wax
Forum topic by oneclickwonder posted 07-18-2019 05:11 AM 10414 views 0 times favorited 4 replies Add to Favorites Watch
View oneclickwonder's profile
oneclickwonder
9 posts in 877 days
07-18-2019 05:11 AM
Topic tags/keywords: rubio monocoat walnut osmo wood wax finishing shellac side table
I’m about to finish a live edge black walnut slab that will be used as a decorative side table or bench of sorts – it’ll sit below a windowsill and hold plants, vases, etc. I am considering two products – Rubio Monocoat and Osmo Wood Wax finish. Both products are an oil hardwax blend. I follow a lot of woodworkers on Instagram and am really impressed with how Rubio finishes walnut slabs – it just looks fantastic. I’ve also read really good reviews from people who have used it. Osmo on the other hand, I haven’t seen the results of as much. But it comes well recommended a lumber supply store I buy from. And online reviews seem to be really complimentary also. A big difference is price – since I can’t get Rubio in my city, it’ll cost me nearly $100 for product plus shipping from Ontario Canada. And that’s only a 350ml can. I can get Osmo locally for about $65 for a 750ml can. Either will suffice for coverage – I just get leftover for the next project with Osmo.
Anyone use either or these products? Particularly on walnut slabs?
I’m also somewhat considering shellac – but I’ve never used and I worry about getting that high sheen, dipped in plastic look or messing it up so you can see brush marks in the finish. I prefer the warmth of a hand-rubbed wax look and have always found using oils and waxes fairly foolproof.
Thanks.
View SMP's profile
SMP
4972 posts in 1195 days
#1 posted 07-18-2019 05:45 AM
Well, i know Matt Estlea likes the Osmo Polyx, and Tools For Working Wood sells it, so its got to be good. I have wanted to try it but haven’t wanted to pay the shipping. My local hardwood/hardware store only carries the livos and the rubio. But the rubio is just outrageously expensive where i won’t buy it on principle
View RubioMonocoat's profile
RubioMonocoat
1 post in 871 days
#2 posted 07-18-2019 07:27 PM
Obviously we prefer our product. I wanted to mention that our product goes really far. 1 Liter will finish approx 300-500 sq ft. That works out to approx 140sq ft for the 350ml size.
Best of luck in finishing your project and let us know how it turns out if you choose to try out Rubio Monocoat!
View CaptainKlutz's profile
CaptainKlutz
5032 posts in 2783 days
#3 posted 07-19-2019 01:59 AM
Don’t forget about Fiddes hard wax oils. They work similar to Osmo.
Drying oil and hard wax blends have been around for centuries. Key to making one is dissolving the wax into a safe low viscosity solvent. So use a light weight oil and melt the wax to allow dispersion and blending
They are many drying oils to choose from and are sold in bulk cheap everywhere.
https://en.wikipedia.org/wiki/Drying_oil
Most common hard wax is canauba, Brazil, or palm wax:
https://en.wikipedia.org/wiki/Carnauba_wax
Once you know a little chemistry:
+1 Rubio is too expensive to ever warrant consideration.
PS – using an oil/wax finish in plant stand getting splashed with water once a day, means you better plan for regular re-coating and maintenance. YMMV
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View Andre's profile
Andre
4840 posts in 3095 days
#4 posted 07-19-2019 02:55 AM
I have done a couple of projects in Walnut and used the OSMO’s, highly recommend it! Have never heard of Rubio so cannot offer a comparison. Have used Fiddles but usually only as a top coat to add some luster. Do love the Fiddles hand brush, well worth the high initial cost. Check my projects for the end tables, think I may have also used it on the Teak Coffee table. Word of advice when using the OSMO’s, you always want to use more than really required but just a few drops will spread a long ways.
