Forum topic by cowboyup3371 | posted 07-15-2019 12:25 AM | 1030 views | 0 times favorited | 5 replies | ![]() |
I don’t think I messed up but could someone help put my mind at ease? I choose to burn the letters into this piece of oak before I did the carving around the block to ensure I had everything set correctly. However, obviously now I need to get rid of my pencil marks which means one last sanding effort before I stain this. If I stick to hand sanding and only use 150-grit or 180-grit, will the burn be adversely affected? Or should I plan on going over it again with my wood burning pen? -- Cowboy Up or Quit - If you are going to quit than get out of my way |
