Attaching plywood bookshelf to stone counters
Forum topic by lblankenship posted 07-14-2019 09:31 PM 634 views 0 times favorited 11 replies Add to Favorites Watch
View lblankenship's profile
lblankenship
53 posts in 1122 days
07-14-2019 09:31 PM
Topic tags/keywords: cabinets counters stone built ins
Hey guys,
I’m building a set of builtin cabinets for a client. Basic two door lower cabinets, counter top and bookshelf on the top. For this build the lower cabinets are built separately from the bookshelves. The entire construction is 3/4” poplar ply with solid poplar doors and face frame.
Here’s where my question comes in. The client decided they wanted to do stone counters rather than wooden ones. Does anyone have suggestions on how to attach the bookshelf to the stone counter? Originally I was going to screw up through the wood counter but I’m not sure if that’s as likely with stone.
The bookshelf has a single stretcher along the back at the very top but the rest of the back is open and you will see the wall. I was planning on screwing through this stretcher to attach to the wall. I thought about using some sort of construction adhesive to fix the bottom to the counter but I wanted to see if anyone else had success with other methods.
Thanks in advance, I appreciate the help.
11 replies so far
View Lazyman's profile
Lazyman
5794 posts in 2235 days
#1 posted 07-17-2019 03:17 AM
I can’t say I have done this but was just wondering: If it is attached to the wall and solid, could it simply just rest on the stone top without and attachment or adhesive?
lblankenship
#2 posted 07-17-2019 03:20 AM
- Lazyman
Yeah I thought about that. I just wasnt sure if you’d be able to wiggle it if you grabbed it by the bottom. The shelving will be attached at the very top and the shelving part is 5 feet tall.
Lazyman
#3 posted 07-17-2019 03:32 AM
How about drilling a small hole in the counter top and stick a dowel or metal pin int the hole? Might want to get the company cutting the stone to drill the holes.
Another thought is to sort of trap it between some pieces of corner round or other molding where the counter top meets the wall?
Just thinking out loud.
View SMP's profile
SMP
2447 posts in 753 days
#4 posted 07-17-2019 03:44 AM
100% silicone works very well for this, and cleans up well off the stone if you ever remove it. You can get in clear or quite a few colors now.
View therealSteveN's profile
therealSteveN
6241 posts in 1422 days
#5 posted 07-17-2019 04:49 AM
I would think the question there, is the “counter” level so that setting down on it wouldn’t create problems. If it is clearly not level, then you have 2 choices either to level it, or do some form of attachment to anchor to the wall. Something like a French cleat maybe? It will solely be a wall mount then , so both top and bottom attachment would be optimal.
-- Think safe, be safe
View Robert's profile
Robert
3932 posts in 2328 days
#6 posted 07-17-2019 02:52 PM
I wouldn’t see drilling through the stone would be an issue. Obviously with client approval.
Or an adhesive.
View Steve's profile
Steve
2188 posts in 1430 days
#7 posted 07-17-2019 03:53 PM
Can you add a metal strip that would attach vertically from the bottom cabinet to the top cabinet in the back?
View clin's profile
clin
1121 posts in 1844 days
#8 posted 07-17-2019 06:14 PM
- Steve
^^^ This is how I’ve seen it done on many pieces of furniture. To some degree, sure you could grab the front of the bookcase and make it move a bit. Maybe only before books get put on it. But so what. Client wants stone top, this is the VERY small price they pay. And if you didn’t tell them, they’d never question it or have any problem with it.
Of course this assumes you can access the back and secure it, before you install it.
I also agree that you could add a dab of some adhesive to further secure it. And if the bookcase can be secured to the wall, like a wall cabinet, then I see no reason to attach it to the base cabinet.
-- Clin
View bilyo's profile
bilyo
1161 posts in 1950 days
#9 posted 07-17-2019 10:25 PM
Could you just mount the shelves on the wall suspended perhaps one shelf height above the stone cabinet top. This way you won’t need to have it fastened to the stone and none of the expensive stone will be obscured. Of course, you will perhaps need to design the shelving a bit differently to accommodate your wall mounts. Or, If the customer wants it to rest on the stone top, go ahead and fasten it to the wall as if it weren’t supported; with fasteners (french cleat maybe) top and bottom.
View Sark's profile
Sark
316 posts in 1208 days
#10 posted 07-17-2019 10:30 PM
Depends on the surface area of the cabinet that is touching the cabinet. If just the frame and sides (i.e. 3/4” strip) are touching, you’d want an aggressive glue, like polyurethane construction adhesive. Or screw it down. If you have a flat bottomed cabinet, any calking or adhesive would work, since the larger area assures good adhesion.
lblankenship
#11 posted 07-23-2019 10:36 PM
Thanks guys, I just spoke with my client and they are now on the fence of whether to do wood or stone counters. Ha. If they decide to go with stone I think I’ll go ahead with a silicone adhesive. I appreciate all the help as always.
