Keeping Swiveling Casters from Swiveling
« back to LumberJocks.com Site Feedback forum
Forum topic by Carly60 posted 07-13-2019 10:28 PM 181 views 0 times favorited 3 replies Add to Favorites Watch
View Carly60's profile
Carly60
2 posts in 70 days
07-13-2019 10:28 PM
Topic tags/keywords: casters swiveling
Hello, I have a conundrum….a bakers rack that I just assembled with swiveling casters. I’m looking for a solution to stop the casters from swiveling and allowing them to only move in-line. The casters have stops on them which is fine but the rack is in a tight space and I need to be able to pull the rack out straight and return it into the space the same way. Is there perhaps a ring, clip or pin that I can use to achieve this? My casters are heavy duty 3” Any suggestions would be greatly appreciated!
3 replies so far
View John Smith's profile
John Smith
1975 posts in 645 days
#1 posted 07-13-2019 10:47 PM
do you have a swivel caster on each leg ?
I find anything with two non-swivel rear casters
and two swivels in the front easier to drive and park.
if you have 4 swivels, you may have to replace two of them.
-- I am a painter. That's what I do. I paint things --
View Madmark2's profile
Madmark2
485 posts in 1070 days
#2 posted 07-13-2019 11:02 PM
Use 2 swivel and two non. Exchange what you have for what you need instead of trying to make the wrong part work.
M
Carly60
2 posts in 70 days
#3 posted 07-13-2019 11:21 PM
Thank you for your recommendation! . I shall give that a go!
