Forum topic by MarineTanker | posted 07-13-2019 10:28 PM | 2984 views | 0 times favorited | 18 replies | ![]() |
Topic tags/keywords: tablesaw question fence Got my father’s Craftsman 10” Deluxe Contractor Saw setup, model number 113.299410 (rebranded Emerson, circa 1996-1997 I believe) with cast iron “grated” wings and original XR2424 fence and add-on Craftsman router extension wing with Craftsman router. I recently used this (along with my Festool track saw) to build custom kitchen cabinets for a remodel. But the XR2424’s teflon glides are either missing or detaching, and the rubber on the adjustment knob has hardened and falling apart so I want replace the fence entirely. It appears the “new” Chinese-made Biesemeyer-branded fences under Delta are no longer up to the quality of the original USA-made ones, so my question is this: What current model fences are recommended for these vintage Craftsman? The Delta 30 in. T-Square Fence and Rail System offered through Home Depot has high reviews (4.4/5 in 142). In fact, one of the reviews has a similar table saw and router wing extension: |
18 replies so far
#1 posted 07-14-2019 12:43 AM |
When I still had my Craftsman 113, I put a Delta T2 fence on it and had no problems with it. -- Bondo Gaposis |
#2 posted 07-14-2019 01:03 AM |
I think the Delta T2 (or T3…whatever the current version is) is smart money for that saw in the $200 range. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#3 posted 07-14-2019 01:28 AM |
I also would say the T2 fence is perfect for the smaller sized contractors, either that or a Vega homeowners, or “Utility” fence. It is a perfect miniature of the Vega Pro, the best, most accurate fence I have ever used. On both looking around the web will likely find you much lower prices. Either will transform that Sears saw into a much higher potential wood cutting machine. -- Think safe, be safe |
#4 posted 07-14-2019 01:37 AM |
Another vote for the delta! My 113 saw is great with a T2 fence on it! |
#5 posted 07-14-2019 01:39 AM |
Dittos on the T2 or T3. No regrets on my buying my T2. larry -- Just a barn cat, now gone to cat heaven. |
#6 posted 07-14-2019 02:35 AM |
The Incra and a good saw blade… -- Desert_Woodworker |
#7 posted 07-14-2019 02:38 AM |
Wow, that is one BEAUTIFUL fence… but at $500+, it’s over 5x the value of the stock table saw itself in its present condition… |
#8 posted 07-14-2019 02:39 AM |
What are the diferences between the T2 and T3? Is it just the T3 being newer? |
#9 posted 07-14-2019 02:40 AM |
My favorite: -- “We all die. The goal isn't to live forever; the goal is to create something that will.” - Chuck Palahniuk |
#10 posted 07-14-2019 02:41 AM |
Think of it like a horse and saddle- you will have a saddle when the horse is gone -- Desert_Woodworker |
#11 posted 07-14-2019 02:43 AM |
+1 on the Mulecab- -- Desert_Woodworker |
#12 posted 07-14-2019 02:49 AM |
Or… build it yourself and you can watch it on YouTube… -- Desert_Woodworker |
#13 posted 07-14-2019 05:34 AM |
Unifence if you want the best :) -- Rick M, http://thewoodknack.blogspot.com/ |
#14 posted 07-14-2019 06:48 AM |
FWIW: IMHO: The T3 is decent fence upgrade for contractor saw, providing using SHORT rails. If you want the 84 inch rails with 52” capacity; suggest the T2 with larger structure is better choice to connect your TS to the extension table legs required for long fence. If you want an industrial T-square fence, and want it cheap: don’t forget you can make your own. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#15 posted 07-14-2019 12:16 PM |
Marine Tanker…see post # 14 larry -- Just a barn cat, now gone to cat heaven. |
Forum | Topics |
Woodworking Skill Share
13540 |
Woodturning
3006 |
Woodcarving
617 |
Scrollsawing
436 |
Joinery
2073 |
Finishing
6705 |
8186 |
34172 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7611 |
1696 |
Focus on the Workspace
2748 |
1295 |
Woodworking Trade & Swap
5574 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9897 |
