Router Lift
Forum topic by PaulDoug posted 07-12-2019 01:42 AM 1293 views 0 times favorited 22 replies Add to Favorites Watch
View PaulDoug's profile
PaulDoug
2360 posts in 2377 days
07-12-2019 01:42 AM
I have a home made router table/cabinet that works great for me, but, I have to lift the table to change router bits or raise/lower the bit I am using. It is kind of a pain, and I always wished I had some type router lift. But it is not in the budget to spend the money for one. I really think I would use my router more if I had a convenient way raising/changing bits. So I have been looking at home built router lifts. There are more option/plan than I thought.. Just wondering if anyone has a home built and does it work good. Was it reasonably easy to build? I am kinda of leaning towards the plans from the “I Built It” site. https://ibuildit.ca/plans/precision-router-lift/ I’ve been watching the related videos and it really seems doable for some one at my level of wood working ability. Anyone else built this one….? Does it work well? I’d appreciate all input.
22 replies so far
View ChefHDAN's profile
ChefHDAN
1554 posts in 3523 days
#1 posted 07-12-2019 10:39 AM
Not to complicate your decision, but given the materials & time to build the one you linked, have you looked at the Router Raizer? It’s on Amazon for $100, I put one in my 3hp PC 10 or 12 years ago and for my uses, it works perfectly, allowing for precision adjustments above the table, and when I’m doing things like cabinet doors I can just set up 3 routers and it’s easy to switch between them by just dropping the plates into the table. Here’s a video on You tube showing how it works
View GR8HUNTER's profile
GR8HUNTER
7147 posts in 1386 days
#2 posted 07-12-2019 02:39 PM
I will be following this I had bought the plans from stumpy nubs BUT have not gathered the parts yet to make it :<((((
ChefHDAN : does this rod have to be used on a plunge router ? I assume ye BUT you know what they say about assumption LOL :<))))
PaulDoug
#3 posted 07-12-2019 04:00 PM
Not to complicate your decision, but given the materials & time to build the one you linked, have you looked at the Router Raizer? It s on Amazon for $100, I put one in my 3hp PC 10 or 12 years ago and for my uses, it works perfectly, allowing for precision adjustments above the table, and when I m doing things like cabinet doors I can just set up 3 routers and it s easy to switch between them by just dropping the plates into the table. Here s a video on You tube showing how it works
- ChefHDAN
Well you did complicate things….. I have not see those before. I have a Bosch 1617EVS router and looks like they have a RZ200 for it although I have not been able, from their site, to determine the difference from the RZ100 and the dealers they list don’t seem to have it….. I will give them a call after I study it some more…. Thanks for the input.
View dschlic1's profile
dschlic1
467 posts in 2643 days
#4 posted 07-12-2019 05:05 PM
I built and use the router lift shown in Shop Notes.
Very good, very accurate. Only change I made was to include a brake on the lift screw.
View controlfreak's profile
controlfreak
563 posts in 275 days
#5 posted 07-12-2019 05:56 PM
I didn’t have a router yet so I looked around. I ended up getting the Triton 3 HP router with built in lift. I got a Kreg plate and drilled a hole for the crank. I would say it works well but I have yet to build the table. Too many projects and so little time.
PaulDoug
#6 posted 07-12-2019 10:18 PM
Still looking and thinking. I do have a question. My router is in an enclosed cabinet with a dust collector hooked up to it. When routing I know there are a lot of chips flying around inside the cabinet as they are sucked into the DC. Do some of the chip get caught in the lift, causing it not to work? I guess not because lots of people have lifts and I don’t read complaints about it. Of the ones I have looked at (home built) I think I like the from Shop Notes, best so far. Less parts and looks like pretty simple.
View PPBart's profile
PPBart
87 posts in 504 days
#7 posted 07-13-2019 02:05 PM
I will be following this I had bought the plans from stumpy nubs …
I built the Stumpy Nubs lift. It’s a good, solid design and the lift action is very smooth and precise—but I have not yet been able to figure out a way to change bits from above. In my case, I just left the back side of the router cabinet open and access the bit from there.
-- PPBart
View Robert's profile
Robert
3655 posts in 2154 days
#8 posted 07-13-2019 02:56 PM
Do some of the chip get caught in the lift, causing it not to work? I guess not because lots of people have lifts and I don t read complaints about it. Of the ones I have looked at (home built) I think I like the from Shop Notes, best so far. Less parts and looks like pretty simple.
- PaulDoug
A valid concern.
I used the Router Raizer for several years and got by fairly well with it. But same issue- you have to remove router from table to change bits.
Another option is Triton which has built in height adj + above table bit changes. I had one for a while, but it developed a backlash issue which Triton tech support told me was “the nature of the beast”. Maybe they have redesigned it, but plastic gears are the issue.
Believe me, I know how money can be an issue but the brutal fact is ww’ing is not a cheap hobby.
View wkndwrnch's profile
wkndwrnch
80 posts in 3042 days
#9 posted 07-15-2019 11:53 AM
I built the stumpy nubs router lift.Works well for me,do not have to remove router to change bits.
GR8HUNTER
#10 posted 07-15-2019 02:01 PM
you guys that built the stumpy nubs one …. what did you guys use for the top ? .... im having some trouble finding the right top :<((((((
View HokieKen's profile (online now)
HokieKen
12748 posts in 1812 days
#11 posted 07-15-2019 03:14 PM
- ChefHDAN
+1 on the Router Raizer. Works great for me and with my Kreg router plate, I can remove the throat ring and change the bit from above the table without having to remove the router. Just requires one bent wrench. One of the best tool upgrades I’ve purchased.
-- Kenny, SW VA, Go Hokies!!!
View Andybb's profile
Andybb
2606 posts in 1277 days
#12 posted 07-15-2019 09:17 PM
- GR8HUNTER
I used plexiglass. Then I gave the whole thing away and bought a used Woodpecker off of CL. Changing bits and adjusting height just took too much time. YMMV.
-- Andy - Seattle USA
View becikeja's profile
becikeja
1060 posts in 3486 days
#13 posted 07-17-2019 10:22 AM
I kicked this idea of building a router lift around for a couple of years. Did I really need one or was it just nice to have? How much accuracy did I really need? Would it just make the bits easier to change or was there more to it?
I Finally broke down and bought the Jessem Rout-R-Lift II. I am shocked at how much easier this has made working with the router table. I can assure you, I will never have a router table without a lift again. I have found the ease of dialing in the depth of cut to be much more beneficial than I ever imagined. Home built tools are nice and can save you some cash, but in the end they always seem to sacrifice something…... at least for me.
View Underdog's profile
Underdog
1473 posts in 2709 days
#14 posted 07-17-2019 11:11 AM
Hey Paul,
I have the Bosch EVS router too, and went looking for router lifts…
Have you seen the Bosch Base Plate lift?
Bosch RA1165 Under-Table Router Base with Above-Table Hex Key
-- Jim, Georgia, USA
View Kaleb the Swede's profile
Kaleb the Swede
1922 posts in 2642 days
#15 posted 07-17-2019 11:20 AM
I use a 20 dollar scissor Jack from Wal-Mart, along with my plunge router. Works good for me
-- Just trying to build something beautiful
