Wood movement in inlaid box lid?
Forum topic by Knowshowrosegrows posted 07-06-2019 03:39 PM 523 views 0 times favorited 8 replies Add to Favorites Watch
View Knowshowrosegrows's profile
Knowshowrosegrows
14 posts in 1406 days
07-06-2019 03:39 PM
I have made a mahogany tea box and cut a 3/16 rabbit all around the top. I’ve made a maple panel to sit in the rabbit on the top. It has really swirly grain and some burl in it.
If I glue the panel into the rabbit then cut off the lid, with the wood movement of the panel distort the shape of the lid over time? Do I use a little glue or glue all along the rabbit all the way around the lid?
8 replies so far
View Andre's profile
Andre
3550 posts in 2573 days
#1 posted 07-06-2019 05:00 PM
IMO, looks like a very small rabbit, small amount of glue 90% chance of failure, 100 glue 50% ?
I would consider loose fit and either hide glue or silicone to attach panel?
Box is small enough so wood movement not going to be a huge problem but humidity can do some major damage!
Knowshowrosegrows
#2 posted 07-06-2019 06:09 PM
Thanks for the advice. Why would I use silicone rather than wood glue?
Andre
#3 posted 07-06-2019 11:37 PM
Silicone stays flexible will move with the wood as will hide glue to a lesser degree. Only problem with silicone no finish will stick to it so either prefinish box or glue it together, apply finish then put small bead on the inside as insurance.
Knowshowrosegrows
#4 posted 07-06-2019 11:46 PM
Thanks so much.
View crippledcarpenter's profile
crippledcarpenter
32 posts in 3213 days
#5 posted 07-07-2019 11:59 AM
you could try option #3 and use a fastener similar to a table top fastener or desk top fastener. just a smaller scale version. it will allow the two different types of woods to expand and contract at their own rates without worry of distortion. you could use small pieces of brass and #1-4 screws
-- haste makes firewood.
View Timmy2Hands's profile
Timmy2Hands
200 posts in 1731 days
#6 posted 07-08-2019 02:59 PM
I make a lot of small boxes and have found in my experience that the panels are so small that the wood movement is negligible to non-existent.
It looks to me that your mitered corneres have been reinforced nicely and should do a good job, and so I would not worry about it too much.
Big panels, big movement; small panels, small movement.
-- Tim McCoy - @Timmy2Hands on Instagram
Knowshowrosegrows
#7 posted 07-08-2019 06:52 PM
Thank you all SO much for your replies!
View SMP's profile
SMP
2099 posts in 672 days
#8 posted 07-09-2019 01:22 AM
I recommend the Titebond hide glue. Has some give as mentioned but much easier to use than the old school hide glue with glue pot.
