Best way to Clean up / Resurface a Cast Iron Router Table Top?
« back to Hand Tools forum
Forum topic by wilschroter posted 07-06-2019 10:47 AM 780 views 0 times favorited 12 replies Add to Favorites Watch
View wilschroter's profile
wilschroter
158 posts in 1408 days
07-06-2019 10:47 AM
I’ve got one of Rockler’s cast iron router tables that’s caught some moisture leading to rust.
https://www.rockler.com/bench-dog-promaxrt-cast-iron-router-table-top
I’m sure this happens with plenty of you guys, but what are you using to the clear the rust off and get a brand new surface? I tried to use “Iron Out” which has worked well for me on other applications around the house but it just made a bit of a mess of the top turning it different shades of blue-ish tones.
12 replies so far
View GrantA's profile
GrantA
2897 posts in 2291 days
#1 posted 07-06-2019 10:51 AM
I use an orbital sander with 220-320 grip paper carefully. Then wax it. Works great.
Do not go at it with a grinder of any type. We like pictures!
6505 posts in 3376 days
#2 posted 07-06-2019 10:53 AM
Scrape off what you can with a razor scraper (really!), then turn to an ROS like Grant said. You can really get cast iron looking good doing that. Also, like Grant said…skip the grinder.
wilschroter
#3 posted 07-06-2019 10:54 AM
Hah I wouldn’t have guessed the ROS would be the first pass. It’s one of those things where you say “You know, this could go very wrong…” but it sounds like an easy fix. I will try to snap before/afters.
GrantA
#4 posted 07-06-2019 10:58 AM
Just keep it flat, don’t try to dig into any spots and if it’s really bad I might use 120-150 grit to start but I’d take it to 220-320 regardless of where you have to start.
View Kirk650's profile
Kirk650
680 posts in 1631 days
#5 posted 07-06-2019 01:26 PM
I used a ROS to get the rust off the top of a shaper my brother gave me. It was very rusty, and I had to use some 150 grit to start with, then went to 220. Then the wax.
wilschroter
#6 posted 07-06-2019 01:50 PM
Worked like a charm! Had to use 150 but such a huge difference. Took about 20 mins.
BEFORE
AFTER
wilschroter
#7 posted 07-06-2019 02:04 PM
Also, what was the wax you were suggesting? I’m using Johnson wax on my planer.
https://www.amazon.com/gp/product/B0000DIWIM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
View Delete's profile
Delete
439 posts in 1255 days
#8 posted 07-06-2019 02:28 PM
I use lots of WD-40 and 250 wet/dry emery cloth mounted in a sanding block with a little bit of sweat investment. A power tool like an ROS is quicker, but you have to be careful not to remove to much around the edges, to preserve a true flat surface.
View moke's profile
moke
1616 posts in 3659 days
#9 posted 07-06-2019 02:42 PM
+1 with Carlos….Cast Iron is softer than you think. An ROS is fine if you keep moving and don’t work one spot too much. You can take it away from being dead flat pretty easily.
-- Mike
#10 posted 07-06-2019 03:44 PM
Looks good, you’re ready to go!
Kirk650
#11 posted 07-07-2019 12:09 AM
It was Johnson’s wax that I used on the shaper. I use it on all the flat metal surfaces in the shop. Most everything is in the air conditioned shop, but the shaper is on the ‘barn side’ – indoors but not in a protected environment. The wax holds up very well. Of course any good wax should be just fine, as long as it based on beeswax. I would not use car wax.
I had a great friend, now deceased, that would come over and visit most days. He’d drink one beer, and between sips he’d rest the beer on my jointer outfeed table. As soon as he was gone I’d wipe off the moisture and rewax that spot. No rust.
View Tony1212's profile
Tony1212
454 posts in 2618 days
#12 posted 07-08-2019 12:57 PM
I use a scotch brite pad with my ROS and WD-40 for rust and wax removal. Then Johnson’s paste wax after that.
Made a video on how to do it.
-- Tony, SW Chicago Suburbs
