Dust collection fittings pant wye vs side wye, vs tee
Forum topic by TelescopeMaker posted 07-06-2019 03:24 AM 2352 views 0 times favorited 25 replies Add to Favorites Watch
View TelescopeMaker's profile
TelescopeMaker
98 posts in 3824 days
07-06-2019 03:24 AM
For a lot of reasons I’ve decided I amd going to use a HF 2ph dust collector as soon as one shows up on CL without getting snatched up first.
And I will be adding a 5” super dust deputy, with 5” 30 gauge snap together ducting from Ace/HD/Lowes. We don’t have menards down here, so that is not an option. Internet shipping prevents a lot of online ordering, but I know there will have to be some.
I’ll try to pre-empt a lot of the usual comments by saying, 5” is uncommon around here, 6” is too big for my shop. But 5” is the right size for me, and it is cheaper than PVC, and pvc drain/sewer schedule 20 is not available here so that is not a choice for me. Stove pipe is, but it is too expensive. I won’t be running into problems with pipes collapsing because the HF dc is not powerful enough for that, and I am reinforcing the thin walls with tight fitting plywood brackets.
This project will only be done with 5” 30 gauge ducting. Of course one of the problems is that the fittings go the wrong way, so I will have to flatten out crimped ends etc for sex change. I will do that and I don’t care. Also, there is only one kind of elbow available here, the adjustable kind from 0 to 90 degrees . There are no other kind of elbow joints here, but that is okay, these are fairly cheap, and will do the job.
But the big problem in designing this right now, are branch intersections.
I must have a branch right off of the cyclone intake. One goes up, the other goes down. I would like to do that with a “true wye” 60-degrees. The bottom goes to the saw, and branches from there to the sander and drill press further down stream as shown in the first drawing. But there is no room for it.
The top goes across the ceiling and drops down on the other side of the shop for the band saw, lathe, and optional downdraft area and main workbench.
My question is, this branch at the cyclone – I know that it can’t be a “tee”, exactly. But I am tight for space, and I see branch fittings that are kind of like a “tee” and kind of like a “wye”. That is, they branch at 45-degrees, quickly, and take up less vital space.
Will it be a huge mistake for me to use this smaller fitting instead of a “pants wye” which would, of course, be better?
Also, I know that it is a good idea to have a long, straight run into the cyclone. That is not an option in my shop, which, as I say is small. (12×20 detached shed)
first depiction shows the “pants wye”,
second shows the idea for the smaller fitting that I am asking about.
-- Telescope Maker, Woodworker, Brewer, Gizmologist, Gardner, Lawn Mower
25 replies so far
View TungOil's profile
TungOil
1382 posts in 1299 days
#1 posted 07-06-2019 03:52 AM
I think you will find option 1 is far superior in performance to option 2, but neither will perform as well as 5 to 10 pipe diameters of straight pipe leading into the cyclone. Both will allow chips into the DC and filter without the straight run.
But sometimes we have to make due with what will fit. Good luck!
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View therealSteveN's profile
therealSteveN
5929 posts in 1378 days
#2 posted 07-06-2019 07:04 AM
Just searched through the local Menards, but I was on the lookout for 6”. I was delighted they had 24 gauge metal that all nested neatly into each other. They only place I got stuck was going down to 4”. All they had were Fernco’s, but they fit both the metal, and 4” PVC, and I know I can get the 4” flex hose on the 4” PVC, so I was good. Just have to assemble, and get one length of 6” flex hose for my joint to the can.
I also have a HF, and I think the 5” will need to go 4” pretty quick, because they had zip, so not having a Menards won’t cost you anything.
On the other side, if a person needed 8” Menards would work out well for you.
-- Think safe, be safe
View GrantA's profile
GrantA
2671 posts in 2212 days
#3 posted 07-06-2019 10:46 AM
I have the HF collector, it was my first. In a 12×20 shop save yourself the trouble of hard line. Just use a flex hose to your tools. Put a quick fit adapter on the hose (just a short piece of pipe that fits inside the tool fittings.
If you want to ride down to South GA I’ve got dust collectors, table saws, jointers, etc to sell you.
View ibewjon's profile
ibewjon
1756 posts in 3597 days
#4 posted 07-06-2019 02:37 PM
Here is a double 4” off 5” y. Can also be made as a double 5, or a 5 and a 4 off of 5”. Just plug the extra port.
ibewjon
#5 posted 07-06-2019 02:40 PM
Steve, here is the tag off a 4” x 6” uncrimped fitting from my Menards in Illinois. Stock item. I use these to adapt to different duct boots for Ras, chop saw, ect.
TelescopeMaker
#6 posted 07-06-2019 07:02 PM
Just searched through the local Menards, ...
- therealSteveN
As I say. Menards is not a store here. not one within 500 miles.
TelescopeMaker
#7 posted 07-06-2019 07:07 PM
I…Just use a flex hose to your tools. Put a quick fit adapter on the hose (just a short piece of pipe that fits inside the tool fittings.
I’m tired of tripping over things as is, so part of this project is to help minimize that.
If you want to ride down to South GA I ve got dust collectors, table saws, jointers, etc to sell you.
- GrantA
Ping me offline, Grant. I am actually looking for a decent used table say. Jet contractor type or hybrid. My old ryobi bt3000 is on it’s last legs
TelescopeMaker
#8 posted 07-06-2019 07:12 PM
- TungOil
Thanks! Yeah, I hate that I have to do it this way. I think I need a shop about 3 times the size, but it wouldn’t be a cozy in the winter ;)
TelescopeMaker
#9 posted 07-06-2019 07:23 PM
- ibewjon
I think 4” would be too constricting and lose efficiency, expecially if I replace the impellor later for a Ricon one.
Notice the horizontal compactness of the second drawing? That is what I am after. Otherwise, I am going to have to move lighting fixtures around which I don’t really want to do, since I just put them in about 9 months ago.
You make these things from scratch, Jon? That is well done, I have to say.
ibewjon
#10 posted 07-06-2019 09:53 PM
Thank you. Yes, a little practice, then easy. It can also be made all 5”, I just don’t have one made. It could be cut down a little shorter, maybe an inch less. I learned from a couple old sheet metal workers. If you want the pattern, I can post it.
TelescopeMaker
#11 posted 07-06-2019 11:42 PM
I appreciate that Jon, but won’t need it, I don’t think. There are just so many things I wish I had time for – blacksmithing for one, and sheet metal work for another. I need to clone myself.
ibewjon
#12 posted 07-07-2019 01:02 PM
Understood…I am riding in the same boat, and I retired last fall. They tell me it gets worse!
View wichman3's profile
wichman3
98 posts in 1425 days
#13 posted 07-07-2019 03:43 PM
Ace/HD/Lowes all offer ship to store for free, consider that in your planning. :)
TelescopeMaker
#14 posted 07-07-2019 05:34 PM
Well, I think I have it… I found a 45 degreet t
- wichman3
Yes indeed. I meant to note that. I do that with HD and Ace all the time. They’re a half mile from home and I have an old Ford Ranger.
TelescopeMaker
#15 posted 07-07-2019 05:35 PM
Well, I think I have it… I found a 45 degree tee, and rearranged it a little. Mere inches make a lot of difference in my plan…
