10 foot table design concerns
Forum topic by zombolina posted 07-03-2019 12:21 AM 685 views 0 times favorited 21 replies Add to Favorites Watch
View zombolina's profile
zombolina
37 posts in 2964 days
07-03-2019 12:21 AM
Greetings,
I’ve made one table before, but it certainly wasn’t this large. In the attached drawings, the top is made of 1.5” cedar with breadboard ends, 6.75” wide planks.
The apron and supports are 1.5” poplar, and the legs are 5×5” turned poplar. All the poplar will be painted
M&T joinery at the apron to leg, XL dominos every where else.
My concern it the 87” span between the legs. Will a 5” apron be enough? Is it aesthetic?
The other issue is that the chairs that I have all have arms, and with the current measurements, it looks like it they will crash into the apron.
What say you, hive mind? Would you build as drawn, or do you think it will rack?
Many Thanks. I really hope I finish this one :-)
-- Success is the ability to go from one failure to another with no loss of enthusiasm. -Winston Churchill
21 replies so far
View CWWoodworking's profile (online now)
CWWoodworking
1291 posts in 1145 days
#1 posted 07-03-2019 01:11 AM
I would go with a standard 3.5” apron and use steel f or support. Solves both problems.
View cracknpop's profile
cracknpop
487 posts in 3315 days
#2 posted 07-03-2019 01:45 AM
I have seen many tables that size have a small support leg under the center of the table.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View bilyo's profile
bilyo
1255 posts in 2069 days
#3 posted 07-03-2019 01:49 PM
The center support leg idea is a good one. You might also consider making the apron and frame out of a harder stiffer wood like white oak that is a full 1” thick.
Of course, you could always shorten the chair legs! ;>)
View LeeRoyMan's profile
LeeRoyMan
1472 posts in 693 days
#4 posted 07-03-2019 02:27 PM
I would go with a standard 3.5” apron and use steel for support. Solves both problems.
- CWWoodworking
+1
1/4×2 steel flat bar on the inside of each stretcher. It’s cheap,
(and no need for a center leg)
25” from floor to bottom of stretcher is my minimum.
zombolina
#5 posted 07-03-2019 02:27 PM
Thanks all! Back to the sketch up board. I’m using the cedar because I have a bunch of slabs from an urban deodar, but the white oak, hmmm
View Lazyman's profile
Lazyman
6300 posts in 2354 days
#6 posted 07-03-2019 03:05 PM
I don’t know how well it works for this sort of application because it is designed for computing shelf loading but according to the Saginator, an 87” long 3.5” x 1.5 yellow-poplar board with a 40 lb per foot load will sag less than 1/10th of an inch over the entire span. I am pretty sure that my 10’ table with leaves in it would sag more than that with weight on it. I can press on the middle and see it deflect. White oak was only a .01” improvement. I basically entered a shelf that is 1.5” deep and 3.5” thick into the saginator. I would think that with the additional 1.5” thickness of the top that it should sag even less. Of course you can always test this by supporting the apron board on each end and standing on it to give it a stress test.
View Delete's profile
Delete
439 posts in 1338 days
#7 posted 07-03-2019 03:52 PM
Such a long table with the requirement for arm chair clearance presents a tough problem. One way to get more support is to do a double glue-up of your apron thickness this will greatly increase its strength and allow you to reduce the height to 3”, if you increase the table height to 32” it would allow you to slip an armchair with standard 27” arm height under the table with 1/2” clearance so you don’t scrape up the arms or table. Your drawing indicates that the arm height is less than 27”, if they are say 25” then you can go back to a 30” table height and still maintain the clearance indicated in this very quick scribble to outline the idea.
View SMP's profile
SMP
3171 posts in 872 days
#8 posted 07-03-2019 04:12 PM
As someone else mentioned, steel angle iron would work well and in the corner of the top and the apron screwed in to both. However, aesthetically, I think tables this long just kind of look funny. Unless its designed to be used with leafs, then at least you know the leafs are temporary. Otherwise, it looks like a stretch limo driving down the street. Kind of cool looking at first, but you wouldn’t want to drive it every day. Just my opinion.
CWWoodworking
#9 posted 07-03-2019 04:33 PM
Design wise, the only thing I would change is the over hang, and 3”ish skirt.
10” is odd on a leg table. It will look like you were aiming for a leaves on end look, or were scared of it sagging.
Don’t over think this. Design it with more appropriate over hang(3”ish), and don’t be scared. Steel is strong and easy to work with.
View Jared_S's profile
Jared_S
423 posts in 926 days
#10 posted 07-03-2019 08:50 PM
It was fine as originally desigined…
This is 120” oal, 5” thick legs, 4×1.25” aprons with a 97” span between legs.
No need for steel anywhere in the design, unless you plan on dancing on top with a small block chevy in your arms.
CWWoodworking
#11 posted 07-03-2019 09:02 PM
- Jared_S
Except the arms of the chairs won’t fit under neath.
zombolina
#12 posted 07-03-2019 09:03 PM
Jared, what is the overhang measurement on the one pictured? That’s more of the proportion that I want.
I think 24-48” of leaves would be helpful, but that would take so much more engineering and storage! Unless someone has finished plans somewhere :-)
zombolina
#13 posted 07-03-2019 09:07 PM
Thanks for the drawing Carlos! I may need to build new chairs
Jared_S
#14 posted 07-03-2019 09:34 PM
- zombolina
7.5” overhang edge to leg on the ends (to fit wingback armchairs)
1.25” to the leg and 2.5” to the apron on the sides
Jared_S
#15 posted 07-03-2019 09:46 PM
- Jared_S
- CWWoodworking
If they can’t fit under a 3.5-4” apron id replace the chairs.
