Sealing MDF Workbench Top
Forum topic by Paulson posted 07-02-2019 06:31 PM 1230 views 0 times favorited 14 replies Add to Favorites Watch
View Paulson's profile
Paulson
2 posts in 881 days
07-02-2019 06:31 PM
Topic tags/keywords: mdf linseed oil shellac sealing workbench
Does MDF swell upon the application of boiled linseed oil? I’m sealing the top to a new work bench and will be using linseed oil on the base, so it would be easiest if I could simple use it on the entire thing. Another product I’ve seen recommended is Shellac, but for simplicity I would prefer an oil if it works.
14 replies so far
View ibewjon's profile
ibewjon
2679 posts in 4074 days
#1 posted 07-02-2019 06:36 PM
I used shellac and it worked great.
View bondogaposis's profile
bondogaposis
6067 posts in 3632 days
#2 posted 07-02-2019 06:45 PM
Poly works well, can’t speak to BLO, as I haven’t used it on MDF.
-- Bondo Gaposis
View Cincinnati2929's profile
Cincinnati2929
50 posts in 1189 days
#3 posted 07-02-2019 07:16 PM
I’d go with either wax or thin coats of non-water based finish.
View SMP's profile
SMP
4947 posts in 1187 days
#4 posted 07-02-2019 08:02 PM
Hmmm…if I have any scrap MDF I can try when I get home.
7289 posts in 3774 days
#5 posted 07-02-2019 08:16 PM
BLO does not make it swell, I’ve used it a few times on MDF. But my favorite finish for it is a mixture of BLO, MS, and beeswax.
View tywalt's profile
tywalt
107 posts in 1445 days
#6 posted 07-02-2019 09:23 PM
shellac and poly for me too. Never attempted BLO.
-- Tyler - Central TX
Paulson
2 posts in 881 days
#7 posted 07-02-2019 09:43 PM
Thanks for the input! I’ll be doing test pieces this evening too, but wanted to make sure there was no longer term problems I should consider.
View therealSteveN's profile
therealSteveN
9208 posts in 1855 days
#8 posted 07-02-2019 11:26 PM
BLO, MS, and Poly all in 3rds, dries rock hard, I’ve got a worktop in the garage I did right after we moved here 9 1/2 years ago, and it still looks like it did then. I like the poly, or possibly Fred’s wax for a coating that other stuff will not get a purchase on, glue mostly, but even other finishes wipe off with no smear. So it’s easy to keep clean. I dog holed that bench like an MFT, and the mix keeps the top edges of the MDF from flaking of with nothing more than a very light chamfer on them.
-- Think safe, be safe
View Andybb's profile
Andybb
3346 posts in 1885 days
#9 posted 07-03-2019 12:00 AM
Another option….FWIW I used water based Varathane floor finish. Very tough and very easy to apply.
-- Andy - Seattle USA
View ScottM's profile
ScottM
756 posts in 3428 days
#10 posted 07-03-2019 03:21 PM
I had some old oil poly that I needed to get rid of. Thinned it down with some MS and poured it on and spread it. It will soak in and evaporate quickly. Let it dry and then sanded/smoothed it out between coats. 2 or 3 coats and it is holding up pretty good.
View OSU55's profile
OSU55
2891 posts in 3271 days
#11 posted 07-03-2019 06:10 PM
Would NOT use blo, take forever to dry and cure. Either poly thinned 1:1 or shellac. Poly will have better chemical resistance.
therealSteveN
#12 posted 07-05-2019 03:24 AM
I think you are thinking of raw Linseed oil, which can take a week to dry the first coat. BLO drys to recoat in 15 minutes at 65*. Dries done in 24 hours after 3 to 4 coats.
OSU55
#13 posted 07-05-2019 11:42 AM
- therealSteveN
No, blo. You must use very thin coats. Takes several days to dry if allowed to penetrate which is where the benefit comes from. Thats why I use thinned poly – dries faster, harder, more chemical resistant. Adding japan drier to blo helps but still an inferior treatment.
View BattleRidge's profile
BattleRidge
152 posts in 1497 days
#14 posted 07-06-2019 02:47 AM
I haven’t been a big fan of MDF and chose two sheets of 3/4” plywood (screwed / not glued) together for my combination workbench, assembly sable and outfeed area with a sheet of hardboard affixed by double sided tape for a work surface. The hardboard provides a stable surface, smooth and is easy to replace once worn or damaged.
-- ~Art~
