Edge grain countertop -- plain sawn vs rift sawn?
Forum topic by woodsandwords posted 07-01-2019 06:07 PM 962 views 0 times favorited 6 replies Add to Favorites Watch
View woodsandwords's profile
woodsandwords
5 posts in 891 days
07-01-2019 06:07 PM
Topic tags/keywords: hardwood countertop grain orientation milling edge grain
Hello,
I am looking into making a hardwood kitchen countertop. I see some places recommend ripping the wood and orienting the edge of the board up for stability. What I’m wondering is if that is mainly a technique for making plain sawn material more stable—in other words, is this trying to reproduce the long, straight grain orientation created by rift sawn milling? If I have access to both plain sawn and rift sawn lumber, would it be worth the time and expense to orient the edge grain up in either case?
I know this depends partly on the price of material, so rather than getting too deep into $$$ calculations, I would clarify that the main driving factor here is stability/longevity of the countertop. I suppose that the edge sawn technique also allows for making a thicker countertop, in that you could buy 4/4 lumber and rip it to 1-1/4” and end up with a 1-1/4” thick countertop… but if I have access to 6/4 rift sawn would it make sense to just join together fairly narrow strips of that (maybe 2-3”) without reorienting? Or still better to have edge grain up? (I’m not considering end grain/butcher block options).
Hope that all makes sense and I appreciate any feedback!
View Bill_Steele's profile
Bill_Steele
779 posts in 3023 days
#1 posted 07-01-2019 07:04 PM
I think you’re right—the edge grain (assuming plain sawn lumber) will give you straight grain that you would typically see in quarter-sawn and rift sawn lumber. There may also be some benefit in orienting the wood this way for expansion/contraction. I think wood expands/contracts more across the grain than length-wise or thick-wise(?).
End grain would be different in both looks and functionality (somewhat self-healing).
I think the rift sawn lumber looks nice, but it will likely be more expensive per board foot than plain sawn. Maybe you’ll need less of it than plain sawn? I think it primarily comes down to what you want the end result to look like. Do you want it to look more like a table top or butcher block?
View MrRon's profile
MrRon
6217 posts in 4535 days
#2 posted 07-01-2019 09:27 PM
The problem would be expansion/contraction when ripping the wood, whether it be rift or plain sawn. You would have to rip the stock and let it sit a while before finishing it to a final dimension before gluing it up into a panel. The up/down grain pattern would still be mandatory and maybe a final planing/sanding after glue up to achieve a flat surface. Remember counter tops are exposed to moisture and you don’t want a counter top to warp. That is why counter tops are made of plywood or MDF with a plastic laminate surface; stability. Sure hardwood counter tops look nice, but I wouldn’t want to have to deal with a warped top down the line.
View CWWoodworking's profile
CWWoodworking
2298 posts in 1470 days
#3 posted 07-02-2019 12:20 AM
- MrRon
Why?
OP, I have a 24” wide butcher block made from plain sawn poplar(4/4) turned on edge. sawed it to 1.5”, glued it up, and sanded it smooth. It has laid flat and worked perfectly for 15 years. It gets heavy use.
I think I used TB2 for glue.
View Woodknack's profile
Woodknack
13585 posts in 3671 days
#4 posted 07-02-2019 06:43 AM
Hello,
- woodsandwords
It used to be called rip & flip, ripping flatsawn into strips, flipping, and regluing into a QS panel for more stability. Tage Frid recommended gluing bark side to bark side, heartside to heartside, so the seams are expanding and contracting equally otherwise you can get a step over time. This happened to me on a table I built last year with rip & flip top. You can’t see it but if you run your fingernail across the top you can feel a slight catch at one of the seams because I goofed and glued them up the wrong way around.
View Robert's profile
Robert
4799 posts in 2772 days
#5 posted 07-02-2019 02:57 PM
Yes orienting the edges up will simulate quartersawn as Woodknack said.
With 6/4 the same principle applies.
I think having the thicker top will look much better and well worth the effort. The extra $$’s it might take will soon be forgotten.
woodsandwords
5 posts in 891 days
#6 posted 07-02-2019 10:16 PM
All good thoughts, thank you! I will try the Tage Frid technique as suggested by Woodknack.
