Sharpening Station, is it worth it?
Forum topic by Diego Cassels posted 06-27-2019 05:57 PM 664 views 0 times favorited 13 replies Add to Favorites Watch
View Diego Cassels's profile
Diego Cassels
154 posts in 642 days
06-27-2019 05:57 PM
Topic tags/keywords: jig blade plane sharpening
A practical and fast way to sharpen my tools. ¿Would do you suggest an easier way to sharpening?
Diamond cards (15cm x 5 cm or 6” x 2 “), not really good quality but they do their job!
bottom part to avoid sliding:
Smaller for hand router bits sharpening.
Let me know what you think, show me how you do the sharpening.
-- Diego Cassels
13 replies so far
View HokieKen's profile
HokieKen
11522 posts in 1699 days
#1 posted 06-27-2019 07:52 PM
Mine is pretty much the same, 3 diamond plates and a leather strop all inset into a piece of plywood:
It works great for me. I have gone to using a power sharpener for most things but it still gets used enough that I think it’s worth the space it takes up :-) I also have some oil stones I use for knives but I never bothered to make a dedicated “home” for those.
-- Kenny, SW VA, Go Hokies!!!
Diego Cassels
#2 posted 06-27-2019 10:11 PM
Hokieken, that looks great! Do I see a guide to set the angles? Top left of the picture?
It works great for me. I have gone to using a power sharpener for most things but it still gets used enough that I think it s worth the space it takes up :-) I also have some oil stones I use for knives but I never bothered to make a dedicated “home” for those.
- HokieKen
-- Diego Cassels
HokieKen
#3 posted 06-27-2019 10:26 PM
Yes Diego, that’s a jig I made to set angles in the Veritas sharpening guide laying on it. Works great.
View waho6o9's profile
waho6o9
8800 posts in 3137 days
#4 posted 06-28-2019 12:35 AM
“Sharpening Station, is it worth it?”
Yes.
View Aj2's profile
Aj2
2562 posts in 2358 days
#5 posted 06-28-2019 12:51 AM
Here’s a look at my sharpening station. It’s out side my shop I use a spray nozzle because I do alot sharpening.
Shapton stoner here.
-- Aj
Diego Cassels
#6 posted 06-28-2019 01:09 AM
That looks great, and it includes a water dripper!
Yes.
- waho6o9
-- Diego Cassels
Diego Cassels
#7 posted 06-28-2019 01:13 AM
This looks like a pro sharpener station. I like how you orginized your stones.
Here s a look at my sharpening station. It s out side my shop I use a spray nozzle because I do alot sharpening.
- Aj2
-- Diego Cassels
View JADobson's profile
JADobson
1448 posts in 2671 days
#8 posted 06-28-2019 04:19 AM
Click for details
Here’s mine. I really like having a dedicated station. Reminds me to sharpen more often.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
Diego Cassels
#9 posted 06-28-2019 12:11 PM
Very nice!
- JADobson
-- Diego Cassels
View ADN's profile
ADN
200 posts in 1173 days
#10 posted 07-01-2019 05:14 PM
I’ve tried several different versions and after attending one of Rob Cosman’s handtool courses, I decided to build a new sharping station. Rob uses only 2 “stones” for plane blades, a 1000 diamond plate and a 16000 Shapton, it takes about 60 seconds using his method.
However my station is not about methods, it’s just about having a ready and easy to use location.
This type uses a fish tank pump so there is no requirement for water other than topping off the tank. It’s just a 6 gallon plastic basin with a wood support. Plus it’s just a couple of steps from my workbench, and I did make a cover for it to keep the dust off the stones when not in use.
Having the running water keeps the stones/plates clean, it’s fantastic.
Whatever one decides to use, the main point is to have a ready to use system….
Regards,
Andy
-- mos maiorum
Diego Cassels
#11 posted 07-01-2019 06:32 PM
That looks great Andy, and you have a view to enjoy your sharpening! I agree with you on the “ready to use”.
Regards,
Andy
- ADN
-- Diego Cassels
View MrRon's profile
MrRon
5783 posts in 3804 days
#12 posted 07-01-2019 09:41 PM
The mandatory thing is to use water while sharpening whether it be diamond or stone. Diamond is really only recommended for sharpening carbide. When used on steel, it clogs the pores of the diamond reducing it’s effectiveness. I would only use diamond as a touch up. Diamond cuts fast and can cut too aggressively. Stones have been used for thousands of years and put extremely fine edges on tools. Stone sharpening requires a lot more expertise than with diamond and can take a long time to master. It is easy to put a sharp edge on a tool or knife. The real challenge is to keep that sharpness while in use. I would take a look at some Japanese videos on sharpening. They really have it down to an art form.
waho6o9
#13 posted 07-01-2019 10:11 PM
“Diamond is really only recommended for sharpening carbide.”
Thank you for that Mr. Ron, good to know.
