Tung wood over wood stain?
Forum topic by Bobhill82 posted 06-27-2019 01:14 PM 217 views 0 times favorited 5 replies Add to Favorites Watch
View Bobhill82's profile
Bobhill82
2 posts in 114 days
06-27-2019 01:14 PM
Topic tags/keywords: stain finish questions too trick
I am finishing up a project that I have recently made. Is it a porch swing that I stained a darker color. I am wondering if it is okay to finish it with tung oil or will this not soak into the wood? Any help or knowlenge would be appreciated.
5 replies so far
View LittleShaver's profile
LittleShaver
586 posts in 1130 days
#1 posted 06-27-2019 02:00 PM
Any oil should be fine. None are going to provide much protection from the elements.
-- Sawdust Maker
View bondogaposis's profile (online now)
bondogaposis
5542 posts in 2862 days
#2 posted 06-27-2019 03:26 PM
If you used an oil based stain then that should have sealed the wood fairly well. The tung oil will be fine, but you should wipe it tight after 5-10 minutes or it could get gummy on you. Tung oil is slow to cure, give it a couple of days between coats.
-- Bondo Gaposis
View Rich's profile
Rich
5001 posts in 1100 days
#3 posted 06-27-2019 04:31 PM
Please clarify whether you are talking about pure tung oil or the commonly available tung oil finish from Minwax and others.
Bobhill82
2 posts in 114 days
#4 posted 06-27-2019 07:29 PM
This is just a common one from a local Home Depot. Don’t have pure yet, as I’m not that experienced.
View Rich's profile
Rich
#5 posted 06-27-2019 07:54 PM
This is just a common one from a local Home Depot. Don t have pure yet, as I m not that experienced.
- Bobhill82
Well, they’re two totally different products, in spite of the name. Tung oil finish from Home Depot does not contain a drop of tung oil.
If you want some real tung oil in a quality wiping varnish, get some Waterlox Original Sealer. It costs more, but it’s a much higher quality product than the tung oil “finishes.” Put on three or four coats and you’ll get some pretty decent protection for your project.
