Smoothing plane - fine wood depressions
« back to Hand Tools forum
Forum topic by Feopablo posted 06-27-2019 01:12 PM 563 views 0 times favorited 6 replies Add to Favorites Watch
View Feopablo's profile
Feopablo
2 posts in 1161 days
06-27-2019 01:12 PM
Singing off tune…..Hi all you smart folks. I am finally using a Stanley #4 smoothing plane, sole and sides square and smooth, New blade, sharpened and slightly rounded edges. When I plane a walnut board, I get lines I can only see in reflective light, almost as if the fibers are compressed. Doesn’t seem to be the blade. Any thoughts?
Feel free to email any suggestions, infrastructure.des[email protected]
View AESamuel's profile
AESamuel
105 posts in 2023 days
#1 posted 06-27-2019 02:57 PM
If the lines are going in the same direction as you are planing they could be plane tracks, the corners of the iron digging in. This can be countered by cambering the iron slightly or feathering out the corners when sharpening. Bear in mind that even with rounded corners there is still a transition from straight iron to curved iron, and there is pretty much no way to avoid it entirely.
If they are going across the direction of planing it could be chatter, either because the cap iron and plane iron don’t have a good fit or because the wood isn’t held securely enough.
There are other reasons too, more info or pictures would help.
View Andre's profile
Andre
3622 posts in 2606 days
#2 posted 06-27-2019 03:02 PM
When I re-hone my blades on a 8000 waterstone, 6 strokes flat then 3 with light presure on each side! Makes more sense if you actually see it done?
View HokieKen's profile
HokieKen
14485 posts in 1939 days
#3 posted 06-27-2019 03:03 PM
There’s a possibility that it’s the corner of the plane leaving a track. I like to ease the edges of mine with a file so they have a slight chamfer with a smooth transition. A sharp corner will cut to some extent.
-- Kenny, SW VA, Go Hokies!!!
View CaptainKlutz's profile (online now)
CaptainKlutz
3320 posts in 2295 days
#4 posted 06-27-2019 10:07 PM
+1 If the sides/sole are dead square with sharp edge, you will leave tracks.
Break edge with file and radius slightly with some 100 grit paper.
Don’t want a sharp corner.
- Feopablo
There s a possibility that it s the corner of the plane leaving a track. I like to ease the edges of mine with a file so they have a slight chamfer with a smooth transition. A sharp corner will cut to some extent.
- HokieKen
Feopablo
#5 posted 07-25-2019 01:27 PM
Hi All, back in with my walnut shelves and the number 4. I cleaned up the sole all around with a file and 400 sandpaper…All good now.
Thank you!
View Robert's profile
Robert
3784 posts in 2281 days
#6 posted 07-25-2019 04:40 PM
It pays to pay attention to the sole, especially if you’ve got any gluing going on nearby.
One time a tiny drop of epoxy glue got on the sole of my plane.
What a disaster that was…............
