? ABOUT T&J #99 TRAIN
« back to Coffee Lounge forum
Forum topic by GR8HUNTER posted 06-26-2019 09:45 PM 587 views 0 times favorited 11 replies Add to Favorites Watch
View GR8HUNTER's profile
GR8HUNTER
8030 posts in 1624 days
06-26-2019 09:45 PM
THIS QUESTION IS FOR THE GUYS WHO BUILT THE #99 WOOD BURNING TRAIN FROM TOYS ANS JOYS
DOES THE MAIN TRAIN WHEELS NEED TO BE MOUNTED SEPERATLY OR A SET ON ONE AXLE ? ? ? CAUSE I JUST PUT IT TOGTHER AND THEY DID NOT WORK WELL :<((((
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
11 replies so far
View FrenchGoattoys's profile
FrenchGoattoys
107 posts in 661 days
#1 posted 06-26-2019 10:02 PM
Well, I didn’t build that train specifically. However, for what it is worth, on the train I built, I set the wheels on an axle.
-- KJ, Spokane, WA.: Don’t count the days; make the days count.
View LittleBlackDuck's profile
LittleBlackDuck
5951 posts in 1732 days
#2 posted 06-27-2019 04:00 AM
Hey GR8 remember some jerk hassling you about SketchUp… You had a sabatical a way back to swat up… and if you didn’t I sincerely appologise…. I do have a model of the train that may answer the question… maybe!
But… rest the butt and swat the SU!
View robscastle's profile
robscastle
7512 posts in 3115 days
#3 posted 06-27-2019 06:27 AM
There you go Tony I knew somebody would have the answer.
-- Regards Rob
GR8HUNTER
#4 posted 06-27-2019 01:08 PM
Hey GR8 remember some jerk hassling you about SketchUp… You had a sabatical a way back to swat up… and if you didn t I sincerely appologise…. I do have a model of the train that may answer the question… maybe!
- LittleBlackDuck
sorry but me and SU do not work well together
I HATE IT OR IT HATES ME :<((((((
View SouthavenToyMaker's profile
SouthavenToyMaker
216 posts in 2399 days
#5 posted 06-27-2019 03:02 PM
The loco I completed was a solid axle. I will say it took a lot of tinkering to get the wheels to turn correctly. If memory serves me right, the holes in the wheels for the piston have to be exactly 180 degrees from one another or they won’t turn
-- Sean
GR8HUNTER
#6 posted 06-27-2019 11:20 PM
The loco I completed was a solid axle. I will say it took a lot of tinkering to get the wheels to turn correctly. If memory serves me right, the holes in the wheels for the piston have to be exactly 180 degrees from one another or they won t turn
- SouthavenToyMaker
there might be my problem I had turned them only 90 degrees I thought thats what I read in instructions :<(((
LittleBlackDuck
#7 posted 06-28-2019 12:13 AM
- GR8HUNTER
Sorry GR8 but, SU tells you different… You don’t need to be an expert to view models… It’s the 3D perspective that makes it beneficial, even to non-SU savvy viewers.
GR8HUNTER
#8 posted 06-28-2019 12:17 AM
- GR8HUNTER
Sorry GR8 but, SU tells you different… You don t need to be an expert to view models… It s the 3D perspective that makes it beneficial, even to non-SU savvy viewers.
- LittleBlackDuck
my puter wont let me veiw it says file is too old :<(((
LittleBlackDuck
#9 posted 06-28-2019 01:15 AM
- GR8HUNTER
What version of SketchUp are you using? 2017 is the best free version available (more recent FREE ones are WEB based)... I can give access to a “legal download” that may not be readily available as Trimble are pushing the WEB versions.
Now having said that, if you are adamant in staying SU imune… I believe there are people that still refuse to vacinate…. I won’t push further, but will still offer the poke in the ribs snide remarks in the future….
GR8HUNTER
#10 posted 06-28-2019 01:18 PM
i am NOT using any SU as i do not understand how to use it i am not to technically advanced like some here :<(((
LittleBlackDuck
#11 posted 06-28-2019 02:33 PM
- GR8HUNTER
Drink more casked vino! Keep away from the expensive top shelf stuff. First poke in the ribs…
