Can I find rough sawn cedar planks 18" wide? (9 ft+ long)
Forum topic by wilschroter posted 06-24-2019 01:05 AM 782 views 0 times favorited 5 replies Add to Favorites Watch
View wilschroter's profile
wilschroter
83 posts in 947 days
06-24-2019 01:05 AM
I’m going to be building some 4 face large outdoor columns and I’d like to use cedar planks that are 18” on each side. My local supplier only has 12” width planks (again, rough sawn which is important for the texture).
Is finding 18” wide cedar planks a reasonable task? Just asking in case I’m about to go on a fool’s errand.
5 replies so far
View Andre's profile
Andre
2676 posts in 2228 days
#1 posted 06-24-2019 06:38 PM
Depending on were you are, on the west coast lots of small mills that can cut any size you want, but the bigger it gets more likely to get cracks?
View Ocelot's profile
Ocelot
2275 posts in 3060 days
#2 posted 06-24-2019 07:32 PM
What cedar are you talking about?
Eastern Red Cedar is hard to find in large widths. Western, I think, is more available.
View therealSteveN's profile
therealSteveN
3116 posts in 996 days
#3 posted 06-25-2019 12:16 PM
I’m in SW Ohio, and can source 18” width on some very nice stock locally. Costs a few pennies, BUT…
Won’t be at a Lowes, Home Depot kind of place. Check around to see who sells “specialty lumber” The place I go to has a web page, but this is not shown, you need to call the desk phone and inquire. I’ve found a lot of the true specialty stuff is that way though.
-- Think safe, be safe
View Charlie H.'s profile
Charlie H.
377 posts in 1072 days
#4 posted 06-25-2019 02:57 PM
Finding any 18” wide plank is a formidable task, cedar maybe even more so.
If these are going to be painted I would strongly consider using a Hardi-board type product.
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
View LesB's profile
LesB
2131 posts in 3865 days
#5 posted 06-25-2019 05:02 PM
Have you considered making the columns out of other materials and then sheathing them with 5/8” cedar plywood house siding material which has a rough sawn appearance. Basically it is T1-11 siding without the groves. If you carefully bevel cut the mating corners it will look like solid cedar column.
If you could find the extra wide cedar boards you are looking for they are likely boing to be “center” cuts from the log and that will increase the chance of their splitting. It would probably be better to join smaller boards that are quarter sawn.
-- Les B, Oregon
