Anyone that has used the HarborFreight auger bits...
« back to Hand Tools forum
Forum topic by weedeater64 posted 06-23-2019 12:44 AM 1070 views 0 times favorited 15 replies Add to Favorites Watch
View weedeater64's profile
weedeater64
10 posts in 433 days
06-23-2019 12:44 AM
Yay or nay for use with brace?
Referring to these.
https://www.harborfreight.com/auger-bit-set-7-pc-68166.html
15 replies so far
View SMP's profile
SMP
1199 posts in 328 days
#1 posted 06-23-2019 03:25 AM
I looked at those but ended up paying more for the Irwins with the square shank, even though one of my braces has the super chuck. I had to drill a bunch of 3/4 holes and figured the irwins were worth the money. If I was only doing a few smaller holes I probably would have got the HF ones.
View therealSteveN's profile
therealSteveN
3116 posts in 996 days
#2 posted 06-23-2019 02:37 PM
Any cutting tool, bits, router, or drill will not be close to even a so so bit from another maker. Saw Blades, Sandpaper, and such are also items not to look for much with them. Simple Math equation, most of it is made in Asia at that level of price, so if they are selling it for 20% of what everyone else is selling it for, it’s NOT because they used quality metals/materials.
No free lunch applies to a lot more than food.
-- Think safe, be safe
View MrRon's profile
MrRon
5572 posts in 3665 days
#3 posted 06-23-2019 02:49 PM
HF has no middleman. They deal directly with the public. Imagine if you could buy a Milwaukee or Makita directly from the factory. The price would be more than 50% less. I had a friend who sold tools and he would sell to me at his cost saving me a lot of money.
therealSteveN
#4 posted 06-23-2019 02:57 PM
These are quality auger bits for use with a Brace Just in case anyone has any confusion about what quality augers look like.
View bandit571's profile
bandit571
23208 posts in 3105 days
#5 posted 06-23-2019 04:44 PM
Have 2 sets of vintage bits…..so…I see no need to jump on the HF Haters bandwagon…excuse me, while I pick up another set of their clamps…
EVERY time someone asks about Harbor Freight….there will always be the HF-phobic posters…1/2 of whom have never even been to the place ( without a paper bag over their head…)
Sheesh.
Dime a dozen..
View LeeRoyMan's profile
LeeRoyMan
176 posts in 149 days
#6 posted 06-23-2019 05:11 PM
- bandit571
So what are you saying, are the bits any good or not. There is no need to jump on the hate wagon, just give your opinion on the bits. (noticing that you don’t have them?)
bandit571
#7 posted 06-23-2019 09:28 PM
Don’t need them? I noticed they have hex shanks….not all braces can hold those….
therealSteveN
#8 posted 06-23-2019 09:43 PM
Bandit, seeing that I appear to be the phobic hater you speak of, only person who said not to buy HF cutting tools.
I have several items from them. I advocate some of their tools, especially to noobs who need a tool to get done. I frequently suggest them as 30 days, returned for any reason is a lot better deal than you get a lot of places.
I will not in good conscious suggest to anyone asking about any of their cutting tools, drill or router bits, or sandpaper, pencils, and likely some other stuff that on close inspection, doesn’t cut it, that they are anything except junk. Never have never will.
bandit571
#9 posted 06-23-2019 10:39 PM
Hmmm..
Improved Barber chuck brace…with a 5/16” harbor freight drill bit….came in a large, gray, metal “Index” of drill bits.
Those jaws…
Hold a round shank just fine….
MrRon
#10 posted 06-24-2019 04:56 PM
I haven’t used HF auger bits, but I have used their twist drills, forstner bits and brad point bits. I am satisfied with them. They do the job and can be sharpened. When sharpened, they are usually better than new. I use them for general hole making, but when I need a precise hole in metal, I use a good name brand drill. Drill bits are made by machine, so they don’t exhibit faults of items that are hand made. Only the materials used may be poor.
View Ocelot's profile
Ocelot
2275 posts in 3060 days
#11 posted 06-24-2019 07:45 PM
I have used the HF 18” so called “ship” augers – even cut through nails with one. It worked fine…. but not with a brace.
My fave augers are the Wood Owl tri-cut self-feeding bits, but they are not square shanked either. Beautifully smooth holes they make.
I just have a couple of them, not the set of 15.
-Paul
View chriscarter's profile
chriscarter
16 posts in 513 days
#12 posted 06-25-2019 12:48 PM
Those HF auger bits are designed for power drills. They will technically work in most hand braces with two jaws, but they might be more difficult to grip and you may have problems with slipping when drilling larger holes in harder wood. Note that they only have one spur instead of two, so the drilling will certainly be less fun than with a normal auger bit designed for a hand brace. Lastly, the description says they resist damage from nails, which tells me they are probably too hard to easily sharpen – regular auger bits are definitely not able to resist nails… although at the cheap cost I suppose they are disposable.
I would strongly advise against buying these for a hand brace. New auger bits for braces come in two flavors: the modern Irwin ones that have massive quality control problems, and some boutique stuff that is horribly expensive. If you need auger bits, get them used. There are always tons on the bay. I think I paid $40 for a half set in excellent condition. Just look closely at the pictures for decent spurs, a sharp lead screw, and no bent shafts. There are enough on there that it shouldn’t take long to find a decent set at a decent price.
View OleGrump's profile
OleGrump
322 posts in 767 days
#13 posted 06-25-2019 11:04 PM
I’ve used the stubby ones with a brace many times and was quite pleased with them for occasional use. You’ll want regular tapered shank bits for deeper and/or more frequent use.
-- OleGrump
View Eric's profile (online now)
Eric
51 posts in 660 days
#14 posted 06-26-2019 11:29 PM
When I read the 1 star reviews I wonder if the unhappy users spun the Harbor Freight bits at high speed with a power hand drill. I already have 1.5 sets of Irwin and a set of Chinese fostners so I doubt I’d buy these.
-- Eric
View mike02719's profile
mike02719
120 posts in 4208 days
#15 posted 06-26-2019 11:59 PM
Bought a set of long (14”) twist drills for one specific job. I was drilling thru the sill of home. Not especially hard wood. The first was a 1/4”. When I withdrew the drill, the flutes were straight furrows. Upon return, they thought this drill had escaped hardening. At least I got my money back.
-- Mike, Massachusetts
